Please help!
Old Jan 28, 2020 | 03:16 PM
Girl_michanic2019's Avatar
Please help!
Okay so my 2005 chevy colbolt just started drinking the gas down. Like way fast so I was under the hood and checked my oil and there is gas getting into my oil somehow. To where the dipstick is showing over full in oil. What is the cause and fix for this? Thanks in advance!
Old Jan 28, 2020 | 03:24 PM
exninja's Avatar
Likely culprit is an injector stuck open.
Old Jan 28, 2020 | 03:26 PM
Okay and how do I check to see which injector it would be?
Old Jan 29, 2020 | 08:33 AM
jdbaugh1's Avatar
Do you have a misfire or is it running abnormally at all? If you have a misfire that could narrow it down to a specific cylinder and you should be able to quickly pull the spark plugs and the plug in the misfiring cylinder should be a little damp and smell like gas.
Old Jan 29, 2020 | 10:50 AM
steelmesh's Avatar
Down the bad injector path: Also, you could 1-by-1 unplug the fuel injectors until there is no change in the idle quality or if you can't start it. So if you unplug the bad cylinder it would not change how the engine idles. Then if you unplug a good cylinder, it would run a lot worse or not even run at all until you plug that good cylinder back in. So the injector you unplugged that didn't change how the engine runs is likely the cylinder with your issue.
But for sure check your codes it will probably tell you what cylinder then you can do the unplug test in one try.
bri2203
Feb 2, 2012 03:55 PM
SymbioteLT
Mar 2, 2008 10:08 AM
beercan
Apr 24, 2007 09:02 PM
beerbaron105
Jun 3, 2006 10:07 AM
Calgden
Jan 28, 2005 04:56 PM
