Please HELP. GM clutch upgrade/throw out bearing problem
Old Feb 10, 2012 | 01:21 PM
timhebert's Avatar
If fixing that don't help, is the only other option my slave cylinder leaking?
Old Feb 11, 2012 | 01:02 PM
CCrunner84's Avatar
I had went through two slave cylinders when i did this on my redline. I picked up a new SS trans w/ the G85 option and the GMPP clutch. Slave that came with the transmission popped, leaked just like your describing. Decided to use the one that came with the GMPP clutch, it ended up leaking as well.
Finally got another from CED (thank god there local) and it did the trick. I read a majority of the thread, but didn't see if you replaced the hard line or not inside the trans? The little rubber cap has a tendency to get stuck in that metal piece that clips on and causes problems.
Hopefully you get this figured out, it made me miss my clutch fork in my TT Stealth lol.
Old Feb 11, 2012 | 02:23 PM
timhebert's Avatar
Yea I changed the clutch pipe and checked it again since I started having pronlems
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
