Rebel Build
Rebel Build
We have a new project on the go to test out some new products and to show the ability and reliability of older projects.
Scope:
List of Parts:
Rebel 3" stainless intake
3.5" Throttle Body with spacer
Rebel 4-1 Stainless Header (equal length)
2.5" Stainless Header back exhaust
60lb's Siemens Injectors with harness
Innovate LC-1 DB kit
CNC port intake, exhaust and chambers
Diamond honed guides, valve job and deck skim
SI Valves Intake Valve - GM Ecotec - 36.1mm (+1mm)
SI Valves Exhaust Valve - GM Ecotec - 31.1mm (+1mm)
Ferrea GM Ecotec Titanium Retainer - use with S10057 valve spring
Ferrea GM Ecotec Dual Valvespring - 75lb on seat, 14mm max lift
GM Valve Seal - GM Ecotec
Head studs
Cosmetic Head Gasket
Rebel Twin Screw Kit
Performance Numbers:
But first a little backgound...
The dyno we use is a dynojet and has always read low or accurate, which ever way you look at it.
Here is a GM Stage 2 dyno:
With...
GM Stage 2 with 3" pulley
GM Honed manifold
GM Cat back exhaust
Rebel 3" Stainless Intake
Now to our results:
Stock:
Ported head, intake and exhaust:
That's a gain of 58WHP and 30WTQ!....stock pulley, stock boost
Ported head, intake, exhaust, 3.5TB, Twin Screw kit:
~~COMING SOON~~
Scope:
List of Parts:
Head studs
With...
GM Honed manifold
GM Cat back exhaust
Now to our results:
Stock:
~~COMING SOON~~
the header is our first which uses 1.75" primaries, equal length and 4-1
downpipe is 2.5" with high flow CAT
cat-back is 2.5" with 18" resonator and straight through muffler
I don't expect Crower to step in for a stroker kit.
Oh and RAW, you didn't swap or grind cams with the new valves?
This interests me greatly. I have been looking into the twinscrew, but I've also been checking out the twincharge kit. Trying to figure which system will make about 300-350 whp efficiently and safely. Good luck with the build, keep us updated with many pics and videos of dyno runs when completed!
In the mean time, your stage 2 kit for my m62 is an option.
No change in boost level might be due to the restriction in the lower manifold but regardless we have let the engine breath a lot easier.
Some of the gain can be attributed to the fact that if the exhaust gas can exit the combustion chamber more efficiently and at a more complete level. Then less fumes are left in the chamber after the exhaust valve closes allowing more air/fuel mixture to get in during the next cycle>>>more power
no, we just wanted to see how the head would perform itself
Last edited by Eng@RebelAutoWorxs; Aug 24, 2008 at 07:19 AM. Reason: Automerged Doublepost
WOW, that is SUPER impressive. I would love to dip into some headwork like that, but I'm gonna wait till the car is paid off. I promised the wife that I wouldn't get too crazy with the car too soon. LOL.
BUT, just to point out a few things, you guys gained 58whp and 30wtq with the stock rev limit. I took notice to that small piece of info. If you guys would have actually reved to about 7000rpms, which I think you would easily make power too now even on stock cams, I'm willing to bet another 10-15whp especially with tuning. Was there any tuning done to that? or was that on stock tune?
That's really impressive, JUST WOW! How much is a head like that? I may tell the wife I just can't wait.
Hooray for stock boost levels!!! Hey Rebel, with the ported head was your increase in flow, and loss of restrictions enough to lower the boost pressure?
