Relative horsepower calculator and example.
"This Relative Horsepower Calculator determines the relative torque and horsepower available at any temperature, barometric pressure, humidity, and altitude. The calculations are derived from public domain information, SAE J1349 Revision, June of 1990. The calculator shows you how much the air conditions on any given day will alter the horsepower of a normally aspirated internal combustion engine."
Here is an example for my car (2005 SS-SC, 2.9" pulley, K&N filter, 42# injectors, shorty header, stock DP, 2.5" custom catback) for this very afternoon in Canmore, AB at around 2:00 PM, some data logged on the Aeroforce Interceptor (MAF lb per min) and other data from the Weather Network or from driver information center (air temp).
Outside Air Temperature: 64 Degrees F
Ambient Barometric Pressure: 29.88 Inches Hg
Ambient Relative Humidity: 18%
Physical Altitude: 4350 Feet
From the above website calculation:
Calculated Relative Horsepower To Rated: 86%
Calculated Dynamometer Correction Factor: 1.163
From Aeroforce: 26.65 lb per min (MAF) @ 6918 RPM (cut-off set at 6900 RPM)
26.65 lb per min x 10 BHP per lb per min = 266.5 BHP (uncorrected)
266.5 x 1.163 (correction factor) = 310 BHP (corrected)
310 BHP x 0.85 (drivetrain loss is 15%) = 263 WHP.
Other data as recorded on the Aeroforce Interceptor:
Max boost: 12.3 PSI
Boost pre-supercharger: 0.3 PSI (vacuum)
Injector: 13.2ms @ 6918 RPM (76.1% calculated duty cycle)
02 sensor voltage: 910 mv (commanded 12.0:1 AFR with HP Tuners)
MAF: 9433Hz
Knock retard starting at 0.3 degrees from 6271RPM up to 2-3 degrees at cut-off
Fuel octane rating used is 91 only.
That is it for today.
Max boost: 12.3 PSI
MAF: 9433Hz
Bye Bye Knock Retard ...
Did another pull tonight ... picked-up 9 whp and all the Knock Retard gone up to 6900 RPM, only by switching from 91 to 94 octane. Calculated and corrected WHP (from datalogging and adjusted to weather conditions) went from 263 to 272.
Last edited by Jmc007; 09-24-2011 at 01:01 AM. Reason: Cut-off still set to 6900 RPM, not 7000.
269 SAE (corrected) WHP.
Did another pull with same setup (and same tank of gas), in quite different weather conditions:
Colder 64.4 degrees F (ambiant)
30.3 in HG (air pressure)
Humidity 33.5%
3510 feet altitude
28.53 lb per min (MAF)
880mv
Coolant temp 176 degrees F
IAT2 around 150 degrees F
"Dyno" correction factor (from formula in post #1): 1.108
Calculated horsepower: 269 SAE WHP; that is pretty consistent with last pull which was 272 SAE WHP. Now I hope to be able to do the next test with the Weapon-R intake, and possibly with their Ram Air setup as well. Results soon to come ...
Humidity 33.5%
3510 feet altitude
880mv
And one last pull before to install the WR intake, again in quite different conditions. Still running 94 octane, now commanded 12.25 AFR and rev limiter adjusted to 7000 RPM, still on stock timing:
53 degrees F (ambiant air temperature)
29.68 in HG (air pressure)
Humidity 62%
3367 feet altitude
850mv
IAT2 lower around 125 degrees F
"Dyno" correction factor (from formula in post #1): 1.117
Calculated horsepower: Roughly the same as before at 271 SAE WHP. Gotta love the corrected numbers ...
Humidity 62%
3367 feet altitude
850mv
Humidity 62%
3367 feet altitude
850mv
Humidity 62%
3367 feet altitude
850mv
I will have to post my results in this thread once I perform some logs.
I enjoy reading your updates.
The key is by using the right multiplication variable (lb per min. per HP) which does differs for boosted applications and normally aspirated applications. Again all of this is theoritical, but ambiant air is affected by barometric pressure and temperature in the same way for both applications.
In regards for the question for the Interceptor HP, I would be curious to know from which sensor it is extrapolated, but I do not have this feature on my older model Interceptor.
My interceptor has almost always showed the same horsepower readings no matter what mods I've done to the car. I tend not to use it, because it isn't very accurate.
I will be running some more tests this afternoon after work. It will only be in the 50's today so I'm interested to see what my car will be flowing. On normal warm days (mid 60's - mid 70's) my cars flows 35.03 lbs/min. On cooler days (low 50's - low 60's) I have logged 36.41 lbs/min.
I'm starting to like using trap speed to determine power. I took my car out on the turnpike Monday, and ran it through the gears with my properly calibrated Gtech Pro RR.... With a shitty 2.334 60' time I ran the following:
9.1 in the 1/8th mile, but it was at 85 mph, and
13.833 in the 1/4 mile at 108 mph.
Elevation was 1350', humidity was 30%, and pressure was 28.5
My mph puts me around 270-280ish horsepower (270-280ish is right around what I dyno'd last year).
Here are my results with Race Gas/High Octane Mode:
Date: 10-21-11
Intake Air Temperature: 55 Degrees F
Ambient Barometric Pressure: 29.93 Inches Hg
Ambient Relative Humidity: 48%
Physical Altitude: 1087 Feet
Calculated Relative Horsepower To Rated: 99.8%
Calculated Dynometer Correction Factor: 1.002
From Aeroforce: 36.14 lb per min (MAF) @ 6970-7250 RPM (Rev limiter set at 7250 RPM, shift point is 7000 RPM)
36.14 lb per min / 0.108 = 334.6296 BHP (uncorrected)
334.6296 x 1.002 (correction factor) = 335.2989 BHP (corrected)
335.2989 BHP x 0.85 (drivetrain loss is 15%) = 285.004 SAE WHP
Max boost: 16.3 PSI
Fuel octane rating: Sunoco 260GT100 (CAM2) High Octane Mode
Timing Advance: 26.5*
Knock Retard: 0.0
Mods:
H62 Hybrid Blower
GMR Stage 3 76mm (2.992") pulley
GMR Stage 3 PCM
GMPP 42 lb/hr injectors
Modified Airbox with K&N E-0777
Badmab Shorty Header
Modified Stock Downpipe
Corsa Catback Exhaust
These results are very close to what I dyno'd last year. Not bad!!
Date: 10-21-11
Max boost: 16.3 PSI
Knock Retard: 0.0
Mods:
H62 Hybrid Blower
GMR Stage 3 PCM
JMC007, the work you did is comparible to some data I gathered and discussed in this thread:
https://www.cobaltss.net/forums/2-0l...epower-135111/
I like what you have done.
I also have my Gtech Pro RR setup to read horsepower and torque very well.
Sometimes I'll get an erratic reading, but 99% of the time it's spot on.
Horsepower readings on the Gtech Pro are much lower than you would see even on a Mustang dyno. I tend to ignore the hp/tq outputs, and look more at the graphs & times.
Date: 10-21-11
Max boost: 16.3 PSI
Knock Retard: 0.0
Mods:
H62 Hybrid Blower
GMR Stage 3 PCM
Date: 10-21-11
Max boost: 16.3 PSI
Knock Retard: 0.0
Mods:
H62 Hybrid Blower
GMR Stage 3 PCM
Humidity 33.5%
3510 feet altitude
880mv
Humidity 33.5%
3510 feet altitude
880mv
https://www.cobaltss.net/forums/6111744-post10.html
First results with the Weapon-R.
Here is the first test done this morning (10:30 AM) with the Weapon-R; looks like not much changed since the other tests with previous drop-in filter. Yesterday I had reset the PCM by disconnecting the negative terminal of the battery for about 2 hours. So now I still see up to 0.2-0.4 PSI of vacuum (pre-supercharger) from mid-range to WOT. Still running on 94 octane fuel. Test always done in 2nd gear:
Outside Air Temperature: 44 Degrees F
Ambient Barometric Pressure: 30.02 Inches Hg
Ambient Relative Humidity: 63%
Physical Altitude: 3415 Feet
Calculated Relative Horsepower To Rated: 91.8%
Calculated Dynamometer Correction Factor: 1.09
From Aeroforce: 28.53 lb per min (MAF) @ 6900-7000 RPM
28.53 lb per min x 10 BHP per lb per min = 285.3 BHP (uncorrected)
285.3 x 1.09 (correction factor) = 311 BHP (corrected)
311 BHP x 0.85 (drivetrain loss is 15%) = 264 WHP.
Other data:
IAT2 around 142F
Coolant 178F
Guess it is time to give some more timing advance; still running on the stock timing table :
Other data:
IAT2 around 142F
Coolant 178F
Last edited by Jmc007; 10-22-2011 at 01:50 PM. Reason: Added comment about PCM reset.
