Running the 2,6" Intense pulley @ 19,5 PSI ...
There is very little to know about the GM until it actually comes out. The major weak link compared to the pioneers, like JMC and the group with the Intense kit, is the pully size. Most people with high power are about 0.3 inches or more smaller than the rumored GM pulley that will be in stage 2.
The GM tune may be more conservative than the methods others are using but this is the big question on the worth of getting the stage kits....
JMC, you said the crank pulley was 6 or less in. Did you actually take the wheel off and the wheel well liner out and measure it or did you just try to do it from the top and get as close as possible? I might take the wheel and all the liners out on the pasanger side and get a accurate measurment.
Originally Posted by Jmc007
For those who wants to know, I'm running up to 21,6 PSI of boost with the 2,6" pulley, logged with the Aeroforce Interceptor gauge.
BUT there is a GOOD amount of knock.
More to come soon, I would just say do not plan to go smaller than 2,8" for now.
I agree w/ Jmc on the blowers "max" from Eaton being conservative. I spoke w/ Bob Stiegemeier on the phone a few months back in regards to porting the m62. He also said that in his experience with the m62 it can handle " 17,000 rpms without sacrificing internal integrity as long as the supercharger is not spinning at that speed consistantly on a daily basis." Now I'm not sure how far that goes in his own point of view, nor am I willing to find out lol.
360 L337 User
Originally Posted by bdwarr6
How do you figure, ive got more mods than rob and he put down 270?
i think he was talking about a 2.6 with stock everything else. not you and the stage 3 intense kit
360 L337 User
you guys are all crazy.. 8000 rpm redline, 20+ lbs of boost. I thought this thing was quick stock. 4cylinder and all. guess I was stupid. my bad.
Keep us posted and let us know what damage yall caue. so we can not.
Originally Posted by Chevypowered
I was considering a 2.7" pulley if i feel the S/C isn't spinning too fast. I'm going to measure the crank pulley today and make my decision. I'll be soo close to the stock 12.5 PSI
If you go to a 2,7" pulley instead of the stock 3,35" pulley, it will boost 6 PSI more over stock. If the total is still lower than 13 PSI, you shoud be able to run the stock injectors, until you run other mods. Still to be validated with a wideband meter for sure.
Originally Posted by BLKSS
Wow! Thats all I have to say. Almost 20lb of boost is crazy. Me and my friends are N/A freaks and im the only one with a SC. My plan was to stick with the GM kit coming out soon just because I dont want to be liable for the damage I can cause and I want to make sure the job is done right. Then again the gains that GM will have will not be close to you guys at all mainly because of pulley size. Is it still worth sticking to GM on this mod? Or should I go for more power and go with a diff kit? Is there something I should know about GM that I don't already know?
#36
#37
Originally Posted by Drewfu$
Are you trying to blow that thing up? I thought the blower was more than maxed out at ~17psi? What are you trying to prove? I think you've got something up your sleeve....
Just for your info, I saw the manifold boost pressure goes up just past 22 PSI last night. I know that is too much for now, that's why I run it with care.
#38
My thought is that we can benefit for the maximum possible TORQUE caused by the smallest possible pulley (probably the 2,6" pulley with a machined snout). Then, to lower the boost for the last RPM's, we could use a kind of wastegate or manual boost controller (set to 18 PSI as a pure example). We could plug it on the intake manifold hose ...
So the boost will goes up to roughly 21 PSI for the midrange, then lowers to 17 or 18 PSI for the last RPM's. Like the SRT-4 guys do (I think).
I found also that a MAP clamp will probably be useful too, helping us to tune the air fuel ratio in a better way. That's what I will try soon.
I also noticed that my Injector Pulse width is about 21,5 Ms at roughly 6 000 RPM's. Because the Max Boost is more than 20 PSI, the differential fuel pressure through the injectors is 60 PSI (fuel rail pressure) minus 20 PSI giving only 40 PSI.
#39
#42
At what altitude are you ? The barometric pressure (at sea level) is 14,7 PSI, but at 14 000 ft of altitude, it drops to 8,7. So that is a 6 PSI loss.
I'm at 7,000 Ft. The pressure is roughly 3 PSI lower than sea level but with the air being less dense I don't think it can compress it as well and adding that onto the already 3 PSI lower makes it a 6 PSI loss. 6.5 PSI is what the interceptor gauge used to read when my car was stock, now I get 11.5 PSI here and 12.6 PSI at 5,000 Ft.
#43
Originally Posted by Shermen
mabey he plans on getting the twincharger kit. but thats a prity shitty boost controller if you ask me.
#44
I notice (experimented) that the Denso Iridium plugs helps a lot to eliminate the "bog" at low RPM's, since they need less energy to spark. For sure the better is to get some step colder plugs when changing the blower pulley size. First I ran the Denso Iridium #IK20 (same heat range than stock NGK) with a lot of detonation (knock) with the 2,6 pulley. Now I ran the NGK BKR7E (one range colder, V-Power Copper) with some less knock. I will try soon some Denso Iridium #IK27 (merely three range colder than stock, just like the NGK BKR9EIX plugs). Rob any knock with the 2,8" pulley ?
#46
Nice to here the crank is smaller, now i can think a bout a 2.7" pulley!! i think those can fit over the stock snout, just need to find someone who makes it. Thanks for the update!!
billetflow makes a 2.7in pully....just a lil fyi
#47
#48
Just receive my manual boost controller ...
As an example, I set it manually, and today my boost goes very quickly up to 16.7 PSI, and stay there until redline.
So with this device, you have the possibility to tune your maximum boost anywhere between 12 PSI (the stock maximum boost or the boost where the stock selenoid bleed the extra boost) and the maximum boost your aftermarket pulley can achieve.
For my example, I can tune the boost anywhere between 12 and 22 PSI with the 2.6" pulley !
It could be nice for those who want to run a small pulley (2.9" or less) and don't want to swap the injectors.
#50
Hey it's kinda cheap, very simple to install, and works VERY well ! I installed it between the by-pass valve selenoid and the by-pass valve actuator lower nipple.
