shift linkage
I just had my 07 SS/Sc repaired, I thought it was linkage of some sort, turns out it was factory defective part. the 5th gear shaft was worn and caused the pin to break in turn I couldn't put it into any gear. Is this the problem your having or is it actually linkage?
you just have to make sure the linkage is properly adjusted. do you have a short shifter. i went through one set already did the install myself and now 2000 miles later no problems
Where exactly did it "break" at? Take the console out and pull the boot up, if everything is fine there then I don't know what the hell has happened unless the two pop-on ball joint ends came off the transmission - I just can't see in my head what would break there........... are you drop kicking it into gear off of a folding chair or something?
EDIT: To the above post ... ah, I see, are those really that fragile? My drop kicking into gear comment still stands
