shorty header or long tube
I'm just wondering if I will notice much of a difference with a long tube header over a shorty header. I already have a catless downpipe with a gmpp maifold.but I want to switch to a true header. So would a long tube be worth it or should I get a shorty header with my catless downpipe?
long= power at higher rpm
short= power at lower rpm
i would say what u have now is a great setup cause realy if u go with a long tube it will only be efective at like 6k rpm.
ok so ive got a a tvs, stock pully, stock head.... with a CA v2 header, would it be best to keep that? i was debating on getting a differant header... zzp midlength or some other type? is it going to be worth the money buying it? thanks!
ok lets just say ur right. and long tube made better power at low to mid-range..... when any car manufacturer is designing a new car they do worry about power believe it or not, but not high rpm, high hp, track only power, they want a low end power band for everyday driving stop and go, they don't want to u to have to hit 5k rpm to make power cause then the life span is decreased. y do they put a short manifold on the car?????
don't worry about 80% of "car guys" don't understand flow and neither did i till i went to school and spent 2 months learning how to make cars go fast.
im not trying to start anything I'm trying to show u whats right, cause i know the internet can be deceiving
yes that is true because there is a vacuum involved ( in most cases) and u have pressure in the exhaust but.......... and exhaust manifold is different. its all about the flow. with the long tube the exhaust gases build up more speed before they get to the collector witch will create a better savaging effect at higher rpm.
z28addiction
Sep 28, 2015 12:03 AM
