The slow Govenor is attempting to go faster
#232
Probably. Either that or ur caliper springs that do the ebrake are shot... Mine were. Cheap fix though after returning my cores i think i spent about seventyfive at autozone for two new calipers.
Thats gotta be tough!
#235
Not really supposed to, but most do. Ideally they should be even just so there is less chance of it popping out, but it can sway a little either way in order to keep them even. You can adjust it down on the caliper if it bothers you. Just pop the bolt and spring off, then pull the mount off that the cable goes into, and move it to a different spline, and re-assemble.
#236
Well an update guys,
First the car, running great. I still think I have a tiny exhaust leak down near the resonator. Also sometimes it seems to stutter on me and wont accelerate. I just have to restart it and its fine. Bad batch of gas maybe?
Me: Shoulder is doing much better. I have full mobility back and working on the strength now.
Ducati: I am dropping of the fairing to be painted on Friday and picking up my mirror extending brackets. When I get back from Brazil ill be putting it back together!
BEDEEEP BEDEEP thats all folks
#238
Alright folks new update, a pretty sad one. I was driving down to the airport yesterday and the car died on me and wouldnt start in Lansing. I had it towed to ZZP and they are going to figure out what is wrong with it. I coudnt miss my flight so I am in Brazil now. Hopefully it will be fixed when I get back. not happy about it all
#247
Update: Talked to Tim at ZZP and it turned out the new DW300 fuel pump burned out the fuse box so they replaced it with a ZZP pump and the fuse box. all that and labor set me back 500. Looks like im gonna have to go after Deatschwerks for that pump/cost of what it did to my car. Wish me luck! On a side not im probably going to have them dyno it while its there.
<--- not a happy camper.
#250
According to this http://www.deatschwerks.com/images/s...nty_policy.pdf
They may not refund me at all... except send me a new pump that I may be able to sell...
