Smashed header
Old 01-15-2019, 02:43 PM
Stumpalump's Avatar
Smashed header
Testing
Weld
Crunch
Fixed?
I had to cut and weld a smashed header in the desert. I think It runs OK. Is it hurting anything?
Old 01-15-2019, 02:47 PM
Looks fine to me. Ive seen dyno tests where they take an engine with headers and do a baseline, then smash the runners in with a hammer and the power stays about the same. I see no issue with what you have there if youre happy with how it runs.
Old 01-15-2019, 03:37 PM
Sharkey's Avatar
denting a primary tube is one thing, but it looks like that "collector" is restricting the top primary tubes quite bad. keep in mind that if you cant get rid of the exhaust it will drive cylinder temperatures up leading to detonation, and ultimately breaking a piston or hammering out a rod bearing. i would be cutting off that collector and building a new one.
Old 01-15-2019, 03:40 PM
I agree with you Sharkey, but have you seen how the stock headers look for these NA engines? The outlet is tiny compared to what he has there with this aftermarket header.
Old 01-15-2019, 07:29 PM
Sharkey's Avatar
yea, a stock n/a manifold isnt great flowing, but thats not really relevant here. this is in a sand car that lives at medium to full throttle most of its life, with a blower and a 2.9 pulley on it. it may not be the end of the world, but its not helping things either.
Old 01-15-2019, 07:36 PM
Damn, I really need to learn how to read. Still, an lsj exh manifold isnt anything great in terms of flow. Gm stage 2 might be close/under his power level and stock manifold was always fine with that, no? Im definitely not as well versed with the lsj than you, but i still think OP would be fine to run the header how it is. Thats just my opinion.
Old 01-15-2019, 08:00 PM
Sharkey's Avatar
like i said, it may not be the end of the world, but its not helping things. a stock manifold is nothing glorious but it has roughly equal flow for all cylinders, here you have 2 cylinders flowing well and 2 that are restricted. without seeing inside the header its hard to tell how restricted it actually is and how much an impact it will have on performance.
like i said, i wouldnt run it like that and id be cutting it apart and building a new collector.
Old 01-15-2019, 10:43 PM
Stumpalump's Avatar
The guy filming this hit me right on the pipe. The car doing the wheelie ia a Funco GTQ with a CBM LS7 stroked to 440 ci Whipple charged, race gas 1100 hp. We went from Glamis to Gordens well California is why its so smooth here. Sorry its FB.
https://m.facebook.com/story.php?sto...00000983144564
If the dent does not hurt that bad then I could run this small runner genuine long tube header vs the 1.75” thats on there??. Do you think I’ll lose with this or gain from the tube length? I guess the question is would you buy another short tube pace setter 1.75” or this long tube?
https://www.kartek.com/parts/kartek-...12-outlet.html
Old 01-16-2019, 12:34 AM
Sharkey's Avatar
that kartech header is a nice looking piece. the long tube design should help increase torque, and that merge collector will help all around. i wouldnt get too hung up on it being 1 5/8 instead of 1 3/4.
Old 01-16-2019, 09:15 AM
armcclure's Avatar
guarantee it still makes more than enough tq to grenade that 6-rib
Old 01-16-2019, 07:05 PM
Stumpalump's Avatar
You can grenade an anvil if you can’t set up a car and drive it. The 091 6 rib transaxle is my favorite. Its super light. The motor is perfect but the whole car is set up for the tranny. Lightened 930 CV’s, gear ratio that allows for 3rd and 4th gears. 1st and second are weak. I tune the coilovers so I can hit stuff fast enough to hold third, paddle tires are cut to spin at will, car is 1760 pounds wet with tools. Pro Am shifter and the right clutch. Brand new Boozer cromo chassis, Very trick 1.2:1 steering rack and toe out alignment front and rear. It turns on a dime and I don’t use a turning break. They are for pussies that can’t huck a car. If I ran a bigger tranny I’d need more power. I run with big heavy $80-210k LS V8 cars that break constantly. The hottest and fastest growing class of desert racers are the class 10 cars. Factory sealed ecotec 2.4 class. They weigh 2200-2500 pounds. They run the big tranny Class 10 Race Car | Alumi Craft Race Cars
The street.....? LOL
Deathscythe
08-29-2011 02:19 AM
SuperSport4
04-25-2011 03:33 PM
Asphalt Assault
05-19-2007 11:24 AM
Xenozx
10-22-2006 01:14 AM
JohnyNFullEffect
09-30-2006 11:08 AM
Quick Reply: Smashed header
