SMS Big Bore Throttle Body...
You know the one picture won't work right? They do make one but it wasn't really a big bore it was ported and there wasn't much of a difference reported from the person who used it.
From what I've heard... no noticable power gains... I don't see how much gain could be netted from such a minor increase in size.
Remember... just like your exhaust... any intake mods will only be as good as the smallest part...
Originally Posted by BooSSted
As far as I know, it's only a 2-3mm increase. That's not really enough to notice a power gain.
Remember guys, just cause you're supercharged doesn't mean you need a huge or bigger throttle body. Your throttle body still is bringing in ambient air flow where the velocity of the airflow is just like an naturally aspirated engine (in a way). Basically, you're not making a bigger hole for more compressed air (like for example an turbocharged unit would).
Hopefully this made sense.
Originally Posted by NJHK
This is probably a clue that the stock throttle body size is suffient enough.
and yes, its only like 2-3mm bigger (no gains)
I have it, i didn't feel any real gains from it, but what it did do was get rid of that slight pause between the time you hit the gas, and the car starts moving. I think for for $200 to gett rid of that you can't go wrong.
Yes it is a direct bolt on.
