So uh, help?
Old Apr 29, 2010 | 08:14 PM
damien's Avatar
So uh, help?
Beyond stumped on this.
IAT2 is through the roof. Cruising temps hover 130-140. Car off the IC pump is DEFINITELY flowing they shoot up to 160 and sit there.
The pump works, i hear it and can feel the coolant running through. I squeeze hose from filler neck to H/E and the neck pisses itself. Feel hoses in and out the endplate and feel it flowing. I SEE the coolant flowing. So what the monkey **** is going on? The pump works no doubt about it.
Old Apr 29, 2010 | 08:15 PM
BumbleBee's Avatar
mods?
Old Apr 29, 2010 | 08:16 PM
Do_WorkSS's Avatar
thermostat might be stuck open. my temps would hover around 150-160 and it turned out that a gasket had broke and jammed its way into the thermostat. might wonna check that out. as far as the intercooler goes....i cant help you there.
Old Apr 29, 2010 | 08:18 PM
damien's Avatar
Originally Posted by BumbleBee
mods?
Stage 2 pulley, 60's. Intake header ZZP H/E. Stock one is MIA.
Irrelevant, im talking strictly IC here. Thanks for input though
Old Apr 29, 2010 | 08:19 PM
sundevil07's Avatar
stock endplate?
Old Apr 29, 2010 | 08:21 PM
damien's Avatar
Originally Posted by sundevil07
stock endplate?
Yes.
Old Apr 29, 2010 | 08:44 PM
BumbleBee's Avatar
hmm, cause im running gm stage 2, and only cooling mod i did was option b and was running 120-140 then put my stock ic tank back in and now im at 90s.
Old Apr 29, 2010 | 08:51 PM
utsadude's Avatar
Air in the system?
Sorry, that's always my suggestion for threads about this problem.
Old Apr 29, 2010 | 09:49 PM
Do_WorkSS's Avatar
oh **** my bad. i mis read the post
Old May 2, 2010 | 11:13 AM
damien's Avatar
So I went and looked more at the pump. It shuts off and comes on as it wants to, and yesterday I found it completely dead. Hit it with a hammer and it kicked back up. It was running last night last I checked, but IAT's are still sky high. I think the pumps shot so I'll be doing a new bump+all water for the summer.
