Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   Spark Plugs (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/spark-plugs-270880/)
Bergeron85 Feb 3, 2012 02:56 PM
Spark Plugs
Going to replace the spark plugs in my Cobalt this weekend. Any suggestions? Its A completely stock SS/SC with Borla high flow CAT and muffler.
riceburner Feb 3, 2012 03:04 PM
time and time again i keep hearing ngk brk-07e or something like that. google search something like 'best spark plugs cobaltss.net' or something i'm sure ull find a good thread on here about them. also, i might have a set if ur interested, only used them for 5k miles
Whitnith Feb 3, 2012 03:16 PM
BKR7E are one step colder, which you don't want if you're stock.
Stock plugs are BKR6E if you want to go NGK. I know they aren't gapped correctly for stock, but I couldn't tell you what they should be gapped to.
Bergeron85 Feb 7, 2012 01:30 PM
Got some Autolight double platinum and gapped them .042. Still has a bit of a surging issue. Will do the fuel filter next.
Staged07SS Feb 7, 2012 01:33 PM
The surging is most likely due to spark blow out.
0.042" is too large of a gap for the LSJ.
Gap them to 0.035" if you are stock or lightly modified.
Autolights have been known to give people trouble with these cars.
http://www.crateenginedepot.com/stor...P2630C193.aspx
^ These are what you should have purchased.
Bergeron85 Feb 13, 2012 11:29 AM
Really? I got the gap number from the Haynes book. Really think that the gap should be smaller?
08SStc Feb 13, 2012 12:20 PM
for a FI motor, yes, a .035 gap is much more appropriate. that .042gap sounds like maybe the 2.2 or 2.4l motors
Staged07SS Feb 13, 2012 12:27 PM
The Haynes book along with the actual owners manual provide the wrong gap for the LSJ.
My car's plugs came gapped from the factory at 0.035" (my owners manual claims 0.039" for 07's).
Bergeron85 Feb 13, 2012 02:58 PM
Really? Oh wow, that stinks. I will take them out and re-gap them. Hopefully it will run a lot smoother. Thanks
Staged07SS Feb 14, 2012 07:13 AM
It should run a lot better.
Let me know.
Bergeron85 Feb 14, 2012 08:11 AM
Let me know.
Okay, Probably wont get to it till this weekend. Will update though.
CobaltSS 16 Feb 14, 2012 08:57 AM
Any suggestions for my LSJ? It's tuned with a 2.8 and 60s. I got stock plugs right now and it runs pretty smooth but I need to change them out anyways since they're getting old.
Stay with the stock ones?
Pepsi Feb 14, 2012 09:46 AM
Ngk 2 step cooler
Staged07SS Feb 14, 2012 09:50 AM
Originally Posted by Pepsi (Post 6338321)
Ngk 2 step cooler
No.
For his mods 1-step colder plugs are more than enough.
user 72239 Feb 16, 2012 10:19 AM
When I had my LSJ I bought Autolite's Iridium's, gapped to .032 and never had issues.
I was getting random missfires in my LNF, bought Autolite' plugs and gapped to .032 Missfire gone.
just my .02
BallinBlackbaltSS Mar 24, 2013 12:31 PM
I have an 2006 Cobalt ss sc with CAI stage two i need to replace my plugs and i was looking at the NGK but, was not sure what i needed if i needed 1 colder or 2 colder or what any help would be appreciated thankS! Thats also Just GM stage 2
Whitnith Mar 24, 2013 01:31 PM
1 step colder will be fine, the BKR7E.
BallinBlackbaltSS Mar 24, 2013 02:02 PM
Thanks!
Staged07SS Mar 25, 2013 07:22 AM
Stock heat range.... stock replacement plug for GMS2.
Gap them at 0.035".
Vander Nars Mar 25, 2013 10:28 AM
I ran 1 step colder on stage 2, wish we had a better guide on when what plug is needed at what stage.
SS89 Mar 25, 2013 10:31 AM
I replaced mine last week and used NGK BKR7E on my stock LSJ, I had bought them for when I'm going to install my 2.9" pulley but installed them regardless.
Staged07SS Mar 25, 2013 10:38 AM
GMS2 was designed with the stock plugs thus why I always recommend them to members asking which plug to get.
I ran the stock plugs through GMR S3, and just recently dropped down to the BKR7E's once I installed my cams.
You can technically run 1-step colder plugs with GMS2, but "can" fall into issues with fouling due to not producing the power / heat to warrant a colder heat range.
You had the GMS2 hardware (pulley, injectors, etc.) but were running a custom tune werent you? Prob making a bit more power than what GM's tune provides.
Vander Nars Mar 25, 2013 12:02 PM
Yeah i had custom tune, im still running 1 step on a 2.7 now just working on some issues
Linkinpark21585 May 9, 2019 10:54 AM
Spark plugs?
I see the stock spark plugs if chosen as NGK are the BKR6E with a heat range of 6 and 1 step colder are the BKR7E with heat range of 7 and 2 steps colder are the BKR8E with heat range of 8. And rule of thumb for every 75 to 100 HP drop 1 step colder when doin internal engine work such as cams and so forth. But what about the iridiums. The BKR7EIX or the BKR8EIX? I have a zzp 2.7 pulley, cold air intake, zzp headers with full exhaust,zzp dual bypass, and zzp larger heat exchanger (radiator). Any suggestions?
