SS/SC Stage Kits
Im interested in getting a stage 2 kit for my car, i want more perofrmance but i dont want to risk reliability too much. How are these things? Stage 3? its still an everyday driver keep in mind. Also, what pully sizes and injectors should i run?
well there are multiple stage kits out there... ottp, zzp, and gms2 are the most common. it's all gonna be in the tune that makes it reliable or not. just get a good tuner and do whatever pulley you want. if you go lower than a 3.0, i'd suggest cooling mods though.
60# injectors 2.8" and get a heat exchanger and good tune
i know someone that went to a 2.8 on 42 ib injectors without a problem... might be a little risky for me but what does everyone else think? right now runnin a 3.1
Im on a 2.8 42# and nos no problems here.
Idc gets a lil high around 7200 but it works fine |
Originally Posted by Tjolley
(Post 7023371)
ZZP Stage 3....60# fuel injectors, 2.8" Pulley, Heat exchanger and a tune.....119000 miles and having no problems at all
Originally Posted by newguy80
(Post 7023373)
option b could help fix any heating problem right? and def need a good tune i would assume... using it as dd so idk how many times i would get to 7200
(Post 7023378)
Opt. B helps bleed air from the cooling system. So it makes the cooling system more efficient, but you will still need the addition of a larger heat exchanger & dual pass to really combat additional heat. Unless you plan to a run a meth setup.
So I stage 3 would be just as reliable as a stage 2 with the right supporting mods?
Originally Posted by KingOnso
(Post 7045707)
(Post 7045710)
Yes.
(Post 7045825)
What would you recommend for supporting mods? |
Originally Posted by JBros35
(Post 7045863)
Intake, exhaust, meth kit, e85
(Post 7045921)
Ok well I already have an AEM Cold Air Intake and GM Performance exhaust, best meth and e85 kits?
Def look into a highflow header/exhaust manifold & downpipe to complete your exhaust system. |
(Post 7045936)
You don't need both. Either go E-85 if it is available, or meth if not.
(Post 7045959)
Ok so if I get the ZZP Stage 3 Kit with #80 injectors E-85 tune I can forget about the meth?
(Post 7045966)
Yes. Do you have a lot of E85 stations near by?
(Post 7045976)
No, guess ill be going with the meth than. Best spot to install it?
Search around, and research a bit. 100%METH is a good member to talk to about the topic as well. |
(Post 7045936)
You don't need both. Either go E-85 if it is available, or meth if not. Def look into a highflow header/exhaust manifold & downpipe to complete your exhaust system. |
