Stage 1 and 2 gain info.(not hp,but how much faster is feels.)
Ijust need some info on the stage 1 and 2 upgrades. Like is it that much faster and worth the 500 or 750 you pay for it. Any info will help please. For instance say the 0-60 is avg like 6.2 depending on ur alltitude, what is it after the stage 2 kit. Thanx
this is how i will explain it... i got stage 1 first because i didint have enough at the time
I already had intake, exhuast, and header but now i got a 7K redline
I felt more power and all mabe because my engine was getting fueled properly! and the 7 k felt pretty good.... But then i got stage 2 right out of the dealer i felt what humans call "love" j/k anyways you knwo how you floor it and you passenger goes flying into the seat? when that happens even worse now but the driver feels this also!
then i added the 2.8 pulley to stage 2 hub and now im running 13.6's and beating evos from rolls
my 0-60 should be in mid 5's
1 yea that might seem like a lot of money but its one of the first things people do when they start moddding keeps warranty
2 when you leave the stealership after you have it done with 500 more redline and the new feel of it leaves a big grin on your face kindof like when you just got the car yea its worth it
can't really post first hand experience with the stage kits at the moment, since its residing in my trunk.... (Stage 1)
I got a mps from Intense, and put a 2.9" pulley on there. Also got their belt tensioner, and swapped to the BK7REs gapped to .35 Car definately has a lot more torque, supercharger whines at anything over 11psi. 1st gear seems pretty useless if you boost it high, you just roast the tires. 2nd gear has the same results if you contine your spin from first....heh
Stage 1 will go on before the months end. Im going to install it, dealer will do the reflash. Not sure who quoted you the $500 for stage 1, but thats steep. I could get you stage 1, and a mps from zzp or intense, and have it to you for $550-$575
This is probably about as far as Im going to take the car, come spring its getting upgraded to a Goat, or something...
yea, Goat=GTO. I miss RWD. The GTO isn't exactly my first choice for appearance, but at this point I don't want to wait for a new Camaro or Challanger. 04 or 05 GTO with an STS turbo system should be more than sufficent, and not that costly either...
I can get you GM stage 1, shipped to your door for $390. Possibly Stage 2 for $495-500 shipped to your door.
Chris~
Chris~
