Stage 2 & 2.8 PLUS 50 Shot????
hey guys i'll be getting my new cobalt ss/sc within two weeks. im going to be putting the stg 2 and 2.8 . what modifcations would i need to run a 50 shot with this??? and how much WHP would i be getting. thanks
Make sure its a wet shot. Also colder plugs and a progressive controller would be good. The controller will allow you to ramp in the nitrous when you know you have traction. FJO makes some good ones.
http://www.fjoracing.com/index.php has a lot of good supporting mods for nitrous.
If you wanna know peak horsepower, I guess just add up the mods a bit. Dyno graph will tell you how fast the car actually will be though.
1 Step Colder Plugs is a must.
And you should run a bit less timing than stage 2 (like stock timing), if you don't have HPT this could be tough to do. You could probably hack something up by modifying the IAT1 signal.
I have run a 50 shot with the stage 2 timing and I got some KR and it seems to have none with the stock timing maps. I would say if you keep an eye on that and adjust accordingly.
To run a 75 you definetly need stock timing.
I ran a 50 shot on a hot dyno with stock timing and had NO knock.
Most nitrous kit instructions will tell you know to run nitrous with a hopped up tune, like the GMS2 because they increase the timing which isn't something you want to do while running nitrous. BTW I actually run a 50 shot on my car so I am speaking from my limited experience.
The zex instructions say:
0 degrees for 50 shot, however with GMS2 your timing is increased over stock so you really need to go back, I would love to seea GM stage 3 PCM calibration and see what there timing maps do.
what did you dyno btw with your setup?
