Stage 2 ZZP
Looking to go with a stage 2 zzp sc kit with 2.9 pulley, zzp stage 2 belt, 60# injectors
Going to be running this with the zzp 3" cai and cat back zzp exhaust Should I get the S3 heat exchanger to help with the cooling or is this not necessary? |
Also would be getting a tune but not sure where to get it from
I'd get Option-B and dual pass over S3 heat exchanger
have you made sure your supercharger coolant pump is working? |
So you’re saying to get the dual pass endplate instead of the heat exchanger? And sounds dumb but how do you check to see if the pumps working? Can only find videos on intercooler pump or is that the same? |
Yeah its the same.
turn car on, check your overflow and see if you have coolant flowing. |
(Post 7696976)
Yeah its the same.
As the car sits now it’s stock and at the dealership right now, picking it up in a few days, trying to figure out the best way to build it |
