start then no start HELP
ok so my dad went and started my car yesterday to move it he said it started fine then shut it off then later on i went out to start it to go to work it started for a sec then shut off went to crank it over again and nothing, i can feel the crank turning just sounds like no spark. now i replaced the plugs 2 months ago with NGK step 2 colder plugs ive tried to jump it and it does the same thing i dont know where to start on trying to get it started i thought about smacking the started with a mallet but if the crank is turning then the starter isnt messed up right ?
Did you check to see if your fuel pump is working?
not yet its 8 degrees outside lol
oh haha I just suggested it because its -15 here and the fuel pump in my truck pooped out on me haha
im going to go check here in a sec ima see if i can here it running
ok fuel pump runs it started for a hot sec again REALLY bad idle for how long it ran and a lil bit of knock due to not being ran and no oil getting up to the in it for two days
bump i need to get my car running
any ideas |
afternoon bump any help ?
Remove the plugs and clean the carbon off them.
Your dad starting it and shutting it off before it got to operating temp fouled the plugs most likely These car run really rich and on cold starts its really bad. |
ok thanks im goin to do that wed and i have a friend coming over to check my fuel pressure bc i dont have a checker
Originally Posted by Coblasts
(Post 5516982)
| All times are GMT -4. The time now is 11:35 AM. |
