Supercharger Maintenance?
Hi there sorry if there's already a thread on this but I have been wondering is there something I should be doing to the blower for maintenance?
Make sure ur belt is good.
Dont over heat your blower (watch your iat's). Thing could potentially warp over time making it less efficient Make sure the vacuum lines coming out of it are not all cracked up if they are, replace them Make sure the coolant in your intercooler system is up to date filled and your i.c. Pump is working Gm says the oil in the blower is good for life, many change it at one point or another just to feel safe but its a debate. |
also the coupler may be a good idea to replace. and when you do that, you're gonna want to change the oil in it anyways
thanks for the info rice!!
I think if Ur running a smaller pulley than stock. Im on a 2.5,i change my sc oil once a year at the beginning of the year. Proly don't need to but its cheap reassurance.
If Ur stock or GM stage 2 i would recommend changing it every 50k. |
Originally Posted by Tjolley
(Post 7135630)
If Ur stock or GM stage 2 i would recommend changing it every 50k. My blower only has about 15k on it, but the oil was pretty clean. I'm not touching the oil again for at least 50k.
Originally Posted by BankerBalt
(Post 7135523)
No need to change the coupler unless you are hearing noise. |
Im just a clean oil nut. I change oil twice a month.
if its not broke don't fix it and post stuff like this in problems and service section
Alright thanks!!
(Post 7135518)
Originally Posted by dirtyb762
(Post 7135891)
This should be stickied somewhere
Not to mention some of it is not 100% correct. IAT's do not hurt the blower. The coolant in the intercooler system is not blower maintenance, etc. |
