Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   thowing a cel with airbox mod (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/thowing-cel-airbox-mod-107041/)
venum_us_2002 Apr 15, 2008 04:35 PM
I started throwing a CEL now that i did the airbox mod so i took it into the dealership cuzz i had a lot of other problems to and they said the reason i am getting a cel is because i am running to lean so i need to put the airbox back to stock? What do you guys think
rnjmur Apr 15, 2008 04:39 PM
Sounds like they should probably check to see if it needs the reflash to correct that problem. If it has been reflashed then it is hard to say.
venum_us_2002 Apr 15, 2008 04:42 PM
Originally Posted by rnjmur (Post 2208402)
Sounds like they should probalby check to see if it needs the reflash to correct that.
But there saying if i put the bottom part of the airbox back on it will correct it. I cant see how taking off the bottom of the airbox can make your engine run that lean to throw a cel
07 SS/SC Apr 15, 2008 04:59 PM
That happens to just about everyone. Nothing to worry about, it is prolly the most common code thrown on our cars. What it is doing is giving the MAF a different reading setting off the CEL, dont worry about it.
rnjmur Apr 16, 2008 01:03 AM
Yes what he said. There was a reflash to correct the problem... however it doesn't correct it all the time.
venum_us_2002 Apr 16, 2008 12:50 PM
if i just leave it will it be okay?
SSCobalt~SSZ24 Apr 16, 2008 12:53 PM
yea the mafs are VERY sensitive
