torque specs?
what are the torque sepcs for the supercharger, and also the torque specs for the zzp pulley, i got the hub on with a hammer and a piece of wood went on nice and slik, but need torque specs for the 5 bolts that hold the pulley on thanks a bunch
I hear ya man. Anybody got an answer for this? I just pulled my charger off to drop a ZZP modular hub system and need the same info.
Supercharger = 18ft-lbs
Pulley = 16 ft-lbs |
Originally Posted by boost_junkie16
(Post 5685389)
16ftlbs is a bit much for those little screws and using a hammer and a block of wood isent to smart i wouldent be suprised if damaged the blower and you could have installed the hub with a power steering pully installer/puller
Originally Posted by mrbelvedere
(Post 5685874)
Those are the specs though. I would snug tighten them in a radial pattern, and call it a day. |
snug is good considering the rotation tightens them up more
I just pulled the specs out of the LSJ build book. As said though, snug should be fine.
