TVS Installed
Old Mar 10, 2009 | 10:58 PM
crt013189's Avatar
Talking TVS Installed
Pics to come but the tvs is installed despite a few setbacks but it is running
Old Mar 10, 2009 | 10:59 PM
Darkmanx's Avatar
Good for u.
Old Mar 10, 2009 | 11:00 PM
SS/SCking's Avatar
Cool what were the set backs?
Old Mar 10, 2009 | 11:05 PM
sick_ss/sc's Avatar
how is it?? was it worth it? i plan on getting on here soon..
Darkmanx's Avatar
probally waiting on a base tune
Old Mar 10, 2009 | 11:31 PM
Rodimus_Prime's Avatar
oh its def worth it
Old Mar 11, 2009 | 12:00 AM
HunterKiller89's Avatar
well for one he didnt know how to reposition the MAP sensor.
Old Mar 11, 2009 | 12:01 AM
crt013189's Avatar
well the sensor that i had to modify and improvising tools to get the beast on other than that it was not that bad also i need a longer vacuum line for the bypass valve the stock one that i transfered is just not long enough and im waiting for the base tune also
Old Mar 11, 2009 | 12:11 AM
what exactly did you modify? I just turned mine
Old Mar 11, 2009 | 12:13 AM
crt013189's Avatar
well I cut mine to the pic that lsjwannabe posted in my earlier thread then i turned it because i just couldn't turn it without cutting it a bit
Old Mar 11, 2009 | 12:38 AM
Darkmanx's Avatar
all you had to do was set it in the 7,0clock position and you need to buy a 9inch allen key to take it off or its gonna take forever.
Old Mar 11, 2009 | 07:12 AM
SS/SCking's Avatar
Oh ok Ill keep that in mind...
Old Mar 11, 2009 | 07:32 AM
sport08's Avatar
thats good get it tuned and dyno time.
Old Mar 11, 2009 | 07:45 AM
crt013189's Avatar
Yeah I used the allen key for the top bolts but the bottom ones where another story and how did you just turn the sensor without modifying it at all unless you didn't bolt it down i can see how you could do it.
Old Mar 11, 2009 | 09:44 AM
oh the bottom bolts are irritating to say the least its hand cramps and cuts all over
Old Mar 11, 2009 | 09:45 AM
Darkmanx's Avatar
yeah your not suppose to bolt it down. IF you turn the sensor once you tighten the sc it holds the sensor in place there is no way the sensor will move if the sc is tightened. and how did you get the bottom bolts if you didnt use an allen key.
Old Mar 11, 2009 | 09:46 AM
SS/SCking's Avatar
Would it be easier with the motor out like mine is?
Darkmanx's Avatar
Hence the reason you buy a 9 inch allen key.
Old Mar 11, 2009 | 09:50 AM
SS/SCking's Avatar
Do you know the size of said allen key?
Old Mar 11, 2009 | 09:51 AM
Darkmanx's Avatar
6mm..
Old Mar 11, 2009 | 11:32 AM
crt013189's Avatar
You can't fit a 9in Allen key on the bottom
Old Mar 11, 2009 | 11:33 AM
schamsy's Avatar
Congrats Man! Cant wait for pics.
Old Mar 11, 2009 | 12:08 PM
Darkmanx's Avatar
omg !! 9 inch is just the length of the allen key so you dont have to get on your knees and get cut and ****, you can stand and do it. if you can fit a 2 inch in there when your on your knees you will be able to fit a 9 inch.
Old Mar 11, 2009 | 12:37 PM
yea i can barely fit anything in the bottom
Old Mar 11, 2009 | 12:54 PM
bowtie32's Avatar
Wow that's awesome!! Hope to see pics soon. Has anyone used the guideline installation that someone Redline posted up?
