under drive pulley information
Rent me! per hour
i personally have known this for years. some of you may not. so i would, if i were you. take the time and read.
http://www.atiracing.com/products/da...mper_dinan.htm
Rent me! per hour
the crank pulley is the weight it is for a reason. along with the stock flywheel.
when one of these is changed, it can cause problems with the bottom end.
Yes that is understood. But the link is talking about removing the harmonic balancer and replacing it completelty with a light weight pulley on a BMW. On our motors we woulndn't be doing that, correct?
Wouldn't making it lighter spin it faster? This link talks about spinning it slower. Unless you mean lightening it and going underdrive? Forgive me if I'm mistaken, I don't know much about cars but am trying to learn as much as I can.
The article explains what can happen when you change the weight anyway...
It can cause problems.. just like lightweight flywheels have known to cause some misfire..
It always seemed strange to me why people would bother with a mode like that for such minimal results. A lot of people with mustangs camaros ect that I know would do pulley swaps and gain 3-4 horsepower but spend hundreds and hours to do it. It always seemed to me like pulley's were a very final mod on a race use motor.
Thanks for the info area, I'll add this to the database that spins in the back of my head for future reference. I was considering a lightweight pulley in the future, but I wont be after reading that. I had figured that keeping it the same size and just lightening it would be OK, but after reading that it makes good sense as to why this would be very bad.
Thanks
BTW, maybe stickey?
Thanks
BTW, maybe stickey?
Last edited by Johnboy12358; Jun 23, 2009 at 01:46 PM. Reason: Automerged Doublepost
Rent me! per hour
wasn't it victory red ss's DD car **** itself and destroy a crank? didn't it also have a lightened crank pulley on it?
but didnt he also have one of the first gen ones that became on here known to leaking the crank seal?
im with rodiums on this one i havnt seen one as a direct result of a pulley on here.
Correct me if I'm wrong, but i thought our cranks were internally balanced and the crank pulley was just that, a pulley and not a harmonic balancer as well.
This is the whole point of that article.... Do not change the weights of essential engine parts.. because its "lighter", it spins with less force, blah blah blah...
Last edited by 07MetallicSC; Jun 23, 2009 at 03:29 PM. Reason: Automerged Doublepost
That was a very good article, but I do have one question. If they are bad (and I am not saying that they are not) why does gmpp make them. I don't know enought about the subject to make an argument one way or the other, I am just trying to learn. I just remembered seeing the gmpp power pulley, and after reading the article, I wondered why they would make one if it can cause that much damage. Here is a link to the part I am talking about.
http://www.crateenginedepot.com/stor...-P330C135.aspx
The purpose of the billet crank pulley is to withstand the rigors of racing applications that involve extended time on the rev limiter.
