Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   Various SS/SC Torque Specs/Ratings (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/various-ss-sc-torque-specs-ratings-193753/)
cobaltguy889 Oct 28, 2009 12:53 AM
I've seen many threads on what the torque specs are for certain parts. I know i've asked before.
Torque specs are hella important, so I figure this should be sticky'd.
A/C Compressor to Block Bolt
20 N·m
15 lb ft
Accessory Drive Belt Tensioner Bolt
32 N·m
24 lb ft
Balance Shaft Adjustable Chain Guide Bolt
15 N·m
11 lb ft
Balance Shaft Bearing Carrier to Block Bolt
10 N·m
89 lb in
Balance Shaft Fixed Chain Guide Bolt
15 N·m
11 lb ft
Balance Shaft Sprocket Bolt
50 N·m
37 lb ft
Baro Sensor and Coolant Return Line Assembly
8 N·m
71 lb in
Boost Solenoid Bracket Nut
10 N·m
89 lb in
Cam Cover to Cylinder Head Bolt
8 N·m
71 lb in
Cam Cover to Ground Cable Bolt
10 N·m
89 lb in
Cam Cover to Ground Cable Stud
10 N·m
89 lb in
Cam Sensor Bolt
8 N·m
71 lb in
Camshaft Position Sensor Housing Stud
22 N·m
16 lb ft
Camshaft Bearing Cap Bolt
10 N·m
89 lb in
Camshaft Sprocket Bolt
First Pass
85 N·m
63 lb ft
Final Pass
30 degrees
Camshaft Timing Chain Tensioner
75 N·m
55 lb ft
Chain Guide Access Hole Plug
90 N·m
59 lb ft
Connecting Rod Bolts
First Pass
25 N·m
18 lb ft
Final Pass
100 degrees
Crankshaft Bearing Lower Crankcase to Block Bolts
First Pass
20 N·m
15 lb ft
Final Pass
70 degrees
Crankshaft Position Sensor Bolt
8 N·m
71 lb in
Crankshaft Position Sensor Housing Studs
22 N·m
16 lb ft
Crankshaft Pulley Bolt
First Pass
100 N·m
74 lb ft
Final Pass
75 degrees
Cylinder Head Bolt
First Pass
30 N·m
22 lb ft
Final Pass
155 degrees
Cylinder Head Front Chaincase Bolt
35 N·m
26 lb ft
Cylinder Head Oil Gallery Plug
35 N·m
26 lb ft
Dipstick Guide to Intake Manifold Bolt
10 N·m
89 lb in
Elek. ICM Cover Bolt
8 N·m
71 lb in
Engine Coolant Temperature Sensor
22 N·m
16 lb ft
Engine Lift Bracket Front Bolt
25 N·m
18 lb ft
Engine Lift Bracket Rear Bolt
25 N·m
18 lb ft
Engine Mount Intermediate Bracket Bolts
100 N·m
74 lb ft
Engine Mount to Intermediate Bracket Bolts
50 N·m
37 lb ft
Engine Mount to Mid-Rail Nuts
100 N·m
74 lb ft
Exhaust Manifold to Cylinder Head Nut
12 N·m
106 lb in
Exhaust Manifold to Cylinder Head Stud
10 N·m
89 lb in
Exhaust Manifold Pipe Flange Stud
16 N·m
12 lb ft
Exhaust Takedown Pipe Nuts
30 N·m
22 lb ft
Flywheel (SMT) Bolt
First Pass
53 N·m
39 lb ft
Final Pass
25 degrees
Frame Bolts
First Pass
100 N·m
74 lb ft
Second Pass
180 degrees
Front Cover to Block Bolt
25 N·m
18 lb ft
Front Lift Bracket Bolt
25 N·m
18 lb ft
Fuel Feed Line
14 N·m
124 lb in
Fuel Feed Line and Injector Harness Bracket
10 N·m
89 lb in
Fuel Line Bracket Bolt
10 N·m
89 lb in
Fuel Pipe Bracket Bolt
10 N·m
89 lb in
Fuel Rail Bracket Stud
10 N·m
89 lb in
Generator Bracket Bolt
42 N·m
31 lb ft
Generator Connector Nut
20 N·m
15 lb ft
Generator to Block Bolt
20 N·m
15 lb ft
Heat Shield to Exhaust Manifold Bolt
23 N·m
17 lb ft
Idler Pulley
22 N·m
16 lb ft
Ignition Coil Bolt
8 N·m
71 lb in
Intake Camshaft Rear Cap Bolt
25 N·m
18 lb ft
Intake Manifold to Cylinder Head Bolt
22 N·m
16 lb ft
Intake Manifold to Cylinder Head Nut
22 N·m
16 lb ft
Intake Manifold to Cylinder Head Stud
6 N·m
53 lb in
Knock Sensor Bolt
25 N·m
18 lb ft
Lower Crankcase to Block Peripheral Bolts
25 N·m
18 lb ft
Oil Bypass Tube
22 N·m
16 lb ft
Oil Cooler
22 N·m
16 lb ft
Oil Filter Housing Cover
25 N·m
18 lb ft
Oil Gallery Plug
35 N·m
26 lb ft
Oil Gallery Plug - Rear
60 N·m
44 lb ft
Oil Level Indicator Tube Bolt
10 N·m
89 lb in
Oil Pan Drain Plug
25 N·m
18 lb ft
Oil Pan to Block Bolts
25 N·m
18 lb ft
Oil Pressure Sensor
18 N·m
13 lb ft
Oil Pump Gerotor Cover Bolt
6 N·m
53 lb in
Oil Pump Pressure Relief Valve Plug
40 N·m
30 lb ft
Oxygen Sensor
42 N·m
31 lb ft
Power Steering Pump Blockout Plate Bolts
25 N·m
18 lb ft
Rear Lift Bracket Bolt
22 N·m
16 lb ft
Spark Plug
20 N·m
15 lb ft
Starter Motor to Block Bolt
40 N·m
30 lb ft
Starter Terminal Nut
17 N·m
13 lb ft
Supercharger Bolts
25 N·m
18 lb ft
Thermostat Housing to Block Bolts
10 N·m
89 lb in
Throttle Body Bolt
10 N·m
89 lb in
Timing Chain Adjustable Guide Bolt
10 N·m
89 lb in
Timing Chain Fixed Guide Bolt
15 N·m
11 lb ft
Timing Chain Oil Nozzle Bolt
10 N·m
89 lb in
Timing Chain Upper Guide Bolt
10 N·m
89 lb in
Torque Converter Bolts
62 N·m
46 lb ft
Transmission to Engine Bolts
75 N·m
55 lb ft
Vent Tube to Cylinder Head
15 N·m
11 lb ft
Water Pipe Support Bracket Bolt
10 N·m
89 lb in
Water Pump Access Cover Bolt
7 N·m
62 lb in
Water Pump/Balance Shaft Chain Tensioner Bolt
10 N·m
89 lb in
Water Pump Bolts
25 N·m
18 lb ft
Water Pump Drain Plug
20 N·m
15 lb ft
Water Pump Sprocket Bolt
10 N·m
89 lb in
A different member (Bolus) posted this table in a different thread to help a member, I just want him to get credited for this.
ShortStack Oct 28, 2009 10:16 AM
Freakin Righteous. I like it.
Pyros777 Oct 28, 2009 11:11 AM
Love the idea. Here are a few frequently used specs that I didn't see on the list:
Stage 2 Pulley Bolts
24 N·m
18 lb ft
Transmission Mount to Transmission Bolts
89 N·m
66 lb ft
Transmission Mount (Rear) to Frame Bolts
60 N·m
44 lb ft
Transmission Mount Through Bolts
100 N·m
74 lb ft
REIGN SS Oct 28, 2009 11:17 AM
...happy? :)
cobaltguy889 Oct 28, 2009 11:23 AM
Thanks Reign
ShortStack Oct 28, 2009 11:36 AM
Can u edit first post OP to show Pyros' addition?
Hodz Jan 11, 2010 08:49 PM
subd
scotch89 Sep 23, 2010 06:31 PM
Valve cover bolts
71 lb.in (6 lb.ft) or 8 N.m
07 BaLt SS Jan 22, 2011 01:38 PM
sub'd
Caivn Jun 13, 2012 11:32 PM
Any torque specs on the end plate bolts?
juice3 Oct 9, 2012 04:39 PM
sub'd
jonathan923 Oct 9, 2012 05:08 PM
didnt think this was around. its always good to know these specs
bratboy90 Oct 9, 2012 06:45 PM
Originally Posted by juice3 (Post 6725337)
sub'd
Wait wait....You bumped this thread just to say.....Sub'd...WOW
Smc252 Nov 18, 2021 10:24 PM
What about the 15mm bolt from intake manifold to block?
