victory_red_SS goes RWD
#1478
I tried to install the AEM and failed misserably. I'm going to let DTP here in virginia install it and if they cant get it to work right ill be going full stand alone.
I'll put up some pictures tomorrow. Don't know if you know the list of stuff i picked up while i was out to sea but so far i have a few installed,
The AEM gauges, the black cat customs gauge overlay, the gps system. Tomorrow a muffler shop is going to install the header for me since some of needs to be welded.
#1479
LSX RWD S/C conversion
yeah, im states side now. I got back monday.
Which part of AEM's stuff is causing you problems???
Standalone does cause a few problems, such as all of your stock switches/gauges. Make sure you do some extra research before just buying one.
You must be dying to drive your car, something I do understand.
#1480
the AEM fuel ignition controller, i think i might have hooked up the crank intercept signal wires backwords. the car started up and ran fine after installed it. then about 5 min later it sent the engine into reduce power mode. so i unhooked it and reconnected the ECU to the sensors and packed the AEM away to let DTP mess with it.
#1482
You don't even feel sorry for me that to buy the SS/TC that i need to sell my truck and scale back on my trailer?????
#1483
reasons why you will recieve no pitty from me
1- you have too much money (maybe not anymore )
2- you will have a very stuid fast cobalt in not too long
3- your wife actually lets you do all this.
I must say my previous gf of 2 years got sick of anything car related anymore so consider yourself lucky that she lets yo do this. lol.
But in all honestly I envy you.
#1484
it works in conjunction with the stock ECU. what it does is takes the signal coming from ECU and manipulates its to do what wants it to do.
the only reason i think i had the leads hooked up backwords was because the car was idling at 1100rpms but on the digital dash board in the software it was reading 5650 rpms
#1485
Not at all. I will give no pity to you sir. hahahah.
As for your #1 reason why I get no pity, I definitely don't have too much money, anymore.
#1487
i hope so, would be nice to get this car finished.
I hope i will, STS got a 4 cyl 197crank hp motor to dyno at 314 whp on 7psi
#1489
That depends on when they are available here in Canada. So far the Canadian GM site doesn't say anything about them and the two dealers I talked to today didn't even know they were coming.
As soon as they can order one for me, I place the order. I will also phone other dealers to see who can get me one first.
#1490
How is the RWD cobalt project comming. I kind of been out of the loop latly. Are you going to be able to drive the RWD balt on the street or is it going to be a strictly drag car?
#1491
#1492
The project itself is coming along and the end of April should see the car move from the fabrication shop to JBP for the drivetrain to be installed.
The cranks are almost done so the first engine starts getting built the beginning of April. The parts have been ordered for the spare engine and that will be built as soon as everything has arrived.
Someone has been paying attention
Last edited by victory_red_SS; 03-16-2008 at 09:33 PM. Reason: Automerged Doublepost
#1499
Hahah with that heavy duty clutch it will make it almost impossible.
