What parts from an LNF will swap onto an LSJ and be considered upgraded?
I know of a few parts that can be swapped from an LNF to an LSJ but I'm probably missing some, and considering the LDK if anything from that.
nothing is worth sswapping over
car
DO NOT attempt to put k04 on LSJ, your tuner will hate you and you will hate your car, get a turbo kit from ZZP or HAHN if you want turbo
The suspension is an upgrade.
brembos!
Brembos
Shifter bracket Seats Front grille Control arms Struts Shocks Springs I think that is it. Timing chain tensions and TOB but those need bought new from GM. |
Originally Posted by mrbelvedere
(Post 7233444)
maybe the seats? |
(Post 7233464)
Brembos
Oil pan
Oil cooler |
(Post 7233464)
Brembos
(Post 7233464)
Brembos
Yeah I would never put a K04 on. And yeah I knew the timing chain tensioner because its revised, already have the new one. Have the lnf tob from ced. I have zzp tranny mounts. I would love to put a set of brembos on.
Do you run a winter wheel/tire setup? I think that the Brembos won't clear 16" steelies.
If you would never put a K04 on it's a good thing you posted this question in the LSJ performance section
Aesthetics is it besides brakes and suspension I ssuppose.
Originally Posted by 06cobalt racer
(Post 7233525)
arent the transmission mounts better on the lnf? i thought that they were |
if you have an 07 SC the Radio in the TC may have the USB port, which is plug and play, well ma need to be unlocked at the dealer.
interior is nicer(IMO) LSD if it has it nd you dont, but your Final drive gearing is better |
Originally Posted by LS6Rally
(Post 7233613)
interior is nicer(IMO) LSD if it has it nd you dont, but your Final drive gearing is better The interior is exactly the same aside from the seats. Define "better". The LNF trans is weaker. |
I was saying if he doesn't have LSD in his LSJ and the LNF does, he could swap it.
and your right on the interior, I should've specified, because I wanted to include the door panles, as they wont match unless the TC is Black/Black. you know how that goes.... |
(Post 7233464)
Brembos
Originally Posted by JapEatr
(Post 7233514)
Oil pan
Oil cooler
(Post 7233615)
LSJ had LSD options.
(Post 7233635)
the control arms are the same
the lnf uses an f35 with a different final drive so how is it weaker LNF control arms have a 1mm larger ball joint and pin that goes into the knuckle. Only the final drive is different? |
(Post 7233710)
you just couldn't NLS the LSJ, so you didn't blow the thing apart in 3rd I guess
(Post 7233710)
(Post 7233765)
