Whats your brew of choice?
So I'm currently running 50% methanol and 50% distilled water. I know some have been more successful running a higher percentage of methanol. I recently went from the 80mm on the TVS down to the 75MM pulley. I was running about as much timing as you can on the 80MM. All other things being the same running the same timing with the 75MM I have 1-4 degrees max knock in 2-3 cells above 6800rpm.
I was able to pull some timing and have it run zero knock across the board but I'd really like to be able to run max timing like I was before with the added boost. I'm moving to a 67% methanol 33% water solution. I'm hoping this change will allow for the added timing.
I'm doing 2 parts pure meth to one part washer fluid. That puts me around 75%. But, I think I might go to 4 to 1 to bump it up more to like 90%. Is there a problem with running 100%??? IDK why I just don't do that.
im running 70/30 meth with 5gph nozzle... running a fair a mount of timing with it... dont know if going to a 7gph nozzle will allow more timing... idk how high people are putting their timing too tho...
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
