Why am I running richer?
I had my car tuned two summers ago and after it was tuned I was seeing afr between 11.8-12.3 which was in florida weather and remained high even when I was in school up north in Maryland but within the last few months for some reason my wideband is reading quite a bit lower. More like 11.4 and if its cold out maybe it will hit 11.7-11.8. Anyone have an idea why this could be? I do have a leak between downpipe and exhaust but that wouldn't make it read richer so i dunno what to think. The wideband is only like two years old. I checked my spark plugs with my mechanic friend and he says they look good. Not to rich nor lean. Any ideas?
im about the same.. when i go WOT my friends say there is a constant black stream coming out the rear of my car. sometimes i can see it by looking at my mirror... sometimes
Do you have an HP Tuners kit?
Mike
The car used to read leaner up north too though. Not just in florida. I also get a p0171 code often which is a lean code so I'm confused why my wideband says i' running richer then it used to.
Wish someone knew the answer to this. I have a misfire on cylinder one. I dunno if it's a stick injector staying open under wot or what but it's weird that when I first got the car tuned it would hit 12.3 and now it's at 11.0-11.2.
well a misfire would cause unburnt fuel into the exhaust and cause you to run rich.....also a lean condition would cause the pcm to add fuel.....so you need to fix your misfire and lean code and you should be alright.
If the injector may be gettin stuck open then that could be a cause of it because it's constantly dumping fuel when it doesn't need it which would cause it to run rich. Have you checked your plugs to see how they're looking?
The check engine light will stay off for weeks then go back on so I would think if it was the sticky injector causing the misfire that it would be on more frequently like whenever I floored it. I guess ill switch the injectors around and see.
well, if you know you have a misfire on cylinder 1......do you have a way to monitor them?? Misfire at idle, or all the time, or just under load?? If at only idle you would either look for a vaccum leak at maybe an injector o-ring, or a bad valve.
You can try swapping injectors, and plug and coil with another cylinder and see if it moves. Check for vaccum leaks, and if nothing shows then check cylinder leakage and compression. But without looking at it for myself I wouldn't be able to say for sure.
Is it a major misfire issue? I had a misfire issue not long ago I checked my injectors and harness all checked out then I checked vacuum lines and I ended up having a small leak, also if your misfiring I would take a look at your plugs again and see how they look it only takes a few minutes and see if cylinder 1 looks foul. Also have you checked your front o2 sensor?
