Why no hybrid L61/LSJ builds?
Old 01-26-2013, 03:40 PM
  #51
Originally Posted by DaFlyinSkwirl View Post
not really.
I had a thread on the LSJ/L61 hybrid I did (lsj bottom end, l61 head) but it got messy because it was when I was figuring out what I needed to do.
swapping heads is pretty easy. There's nothing that really needs to be modified.
it's only when you want to use a plastic intake manifold that the LSJ head needs to be modified slightly. and those mods are all related to the intake flange for the PCV system to work properly.
head-to-block interfaces are all extremely similar. the only thing you need to change inbetween them is the headgasket... for LE5 block based hybrids, you need to use a headgasket that is 88mm bore or larger.
What do you do about the cams/cam sensor? Do you just swap your L61 cams in the LSJ head?
IonNinja is offline
Old 01-26-2013, 03:59 PM
  #52
xxenjoi11's Avatar
Originally Posted by Tjolley View Post
Holy **** this is good ****...
Schools in session boys and girls.
Ive learned more in this thread than any other single thread on this website
xxenjoi11 is offline
Old 01-26-2013, 05:57 PM
  #53
the early L61s had two different length cams. the intake cam was longer (same length as both LSJ cams) and it spins the Jbody power steering pump.
the exhaust cam is shorter.
you can run the L61 cams in the LSJ head, but one of the cam journals in the head will be empty. It has to be filled with either a blank end-journal from a spare cam, or welded shut somehow. Not having a journal in there will cause a tremendous loss in oil pressure.
so far as cam-sensor, the cassette-style wasted spark ignition uses CSI (compression sense ignition) that fires in wasted spark (1 and 4 fire together, 2 and 3 fire together)
since only one cylinder is on the compression stroke, only one cylinder fires.
what the CSI part of the ICM circuitry does is measure the resistance across the spark plugs on the coils that are firing. The one with higher resistance is on the compression stroke, so the ICM generates a cam signal based on that.
by losing the cam sensor, you lose sequential injection. But, much higher than 3000rpm, the engine is on batch fire anyway, so sequential only really hurts MPG a tiny bit.
L61
LSJ
early model L61 showing the different length camshafts
LSJ showing camshaft length detail
again, L61 cam flange
LSJ cam flanges. the intake flange is identical to the L61, but the exhaust flange is totally different than the intake flange.
L61 exhaust cam is too short for the LSJ
L61 intake flange detail
LSJ intake flange detail (you can see the offset PCV hole)
plastic manifolds don't like the LSJ intake flange. I modified this by cutting the manifold clear of the hole, then drilling/tapping the hole for NPT thread and running an external line
L61 upper rad hose connection detail. The hole to the right is supposed to have a nipple.
on the LSJ, there are two holes.. one for the ECT sensor, and another for a banjo fitting for a water pipe that goes across the head up by the fuel rail
styrofoam look of the lost-foam cast heads (L61 here)
sand cast heads look much nicer (and no seepage problems)
also, the LSJ and L61 use different spark plugs. use the plugs that match the head (taper seat vs. crush-washer seal).
DaFlyinSkwirl is offline
Old 01-26-2013, 06:04 PM
  #54
Your knowledge is unbelievable man thank you
07MetallicSC is offline
Old 01-28-2013, 11:12 PM
  #55
Always wondered myself why more of these haven't been done. Ever since I learned about them a while back ago, been wanting to do one. I have a couple hybrid builds planned out now and can't wait to get them done.
SSfamilywagon is offline
Old 02-08-2013, 07:50 AM
  #56
Nope ur lsj parts bolt right in..just need 88mm pistons and 88mm hg
Tjolley is offline
Old 02-12-2013, 02:04 PM
  #57
mrbelvedere's Avatar
I can get a sleeve made for the le5 with a finish bore of 94mm
so that opens up the stroker/hybrids we can do such as
bore stroke
94mm x 98mm = 2.7
94mm x 94mm = 2.6
94mm x 86mm = 2.4
mrbelvedere is offline
Old 02-12-2013, 02:38 PM
  #58
What compression with that higher displacement? 10:1?
ThexGovenor is offline
Old 02-12-2013, 02:42 PM
  #59
what ever you want it to be
Old 02-12-2013, 02:49 PM
  #60
574
bore stroke
94mm x 98mm = 2.7
94mm x 94mm = 2.6
94mm x 86mm = 2.4
I may have **** when I saw this. I wanna build this! haha
574 is offline
Old 02-12-2013, 03:01 PM
  #61
I like to ****
Old 02-12-2013, 03:54 PM
  #62
Yes! a 2.7 Stroker would be ****. what would it cost though to have the sleeves and pistons made?
LS6Rally is offline
Old 02-12-2013, 08:23 PM
  #63
2.7 would definitely be awesome.
nhanson is offline
Old 02-13-2013, 12:09 AM
  #64
maybe there is more knowledge in this thread then the VVT thread. Anyone know if you can use LE5 aftermarket cams in the LAP? a lot of LAP guys would love to have cams.
also 2.7 would be sick ****
rcarr0327 is offline
Old 02-13-2013, 04:59 AM
  #65
to my understanding, the VVT cams are unique to their own engine.
however, again, my knowledge of the VVT setups is extremely limited at best.
Old 02-21-2013, 03:07 PM
  #66
Thoughts on running a LSJ head, LE5 Block, and LSJ crank... It would need custom length rods right? Also if you bored it out to get that higher displacement and sleeved it.. custom pistons?
Old 02-21-2013, 04:33 PM
  #67
what you are refering to is a 2.1 big bore and there are several out there the 2.4 sleeve is also .060 thick same as lsj and you can run a lsj head on a 2.4 no problem all you need is a le5 head gasket and custom pistons you can use stock length rods
Old 02-22-2013, 03:07 PM
  #68
L61 lsj le5 lnf all have the same deck hight 8.700 is factory i think.
Tjolley is offline
Old 02-22-2013, 04:34 PM
  #69
I was referring to your earlier post about being able to make a 2.7 is that on an LE5 block bored out with a longer stroke?
Old 02-22-2013, 05:12 PM
  #70
zrated89's Avatar
The guy I bought my turbo off from was a 2.2 bottom end, and an lsj head. He also made over 600whp on the turbo setup. Was cleanly done as well. Ended up shearing his flywheel bolts off in the crank. I guess the lsj has 8 for a reason lol
zrated89 is offline
Old 02-22-2013, 05:15 PM
  #71
zrated89's Avatar
I have a sleeved 88mm bore block that will need to be bored out to at least 89mm. Anyone know if the le5 head gasket will clear the bore and not over hang into the combustion chamber ?
zrated89 is offline
Old 02-22-2013, 05:21 PM
  #72
LE5 is a 88mm bore/ 98mm Stroke, the 2.7 is a punched out 2.4 block to 94mm
LS6Rally is offline
Old 02-22-2013, 05:31 PM
  #73
Yep thats what I was referring to.
Old 02-22-2013, 08:20 PM
  #74
you wont punch a 2.4 out to 94mm not enough meat
Old 02-22-2013, 09:00 PM
  #75
zrated89's Avatar
not unless u want 2mm sleeves lol
zrated89 is offline
Quick Reply: Why no hybrid L61/LSJ builds?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
