Why no hybrid L61/LSJ builds? - Page 6 - Cobalt SS Network
Old 08-23-2015, 10:25 PM
  #126
Diamonds meant for the lsj are going to do the same thing
Slowbalt2000 is offline
Old 08-23-2015, 10:47 PM
  #127
Diamond makes a set for the 2.2 liter ecotec. http://www.diamondracing.net/pdf/Chevy-Section.pdf
Part number 10000.
barthello is offline
Old 08-23-2015, 10:48 PM
  #128
Slobodan Milošević
07blackg5's Avatar
you will need to use 2.2 rods as well
07blackg5 is offline
Old 08-23-2015, 11:11 PM
  #129
Yup😉
Old 08-23-2015, 11:17 PM
  #130
Right from the L61 build book
"The 2.0L LSJ ECOTEC engine has forged steel rods similar
to Small Block Chevy “Pink Rod.” The forged steel rods are
made of high quality material and have a cap screw 23 mm
small end, and a full floating bronze bushing. These rods are
available through GM under part number 12755126. These
rods require GM Performance Parts piston set part number
88958634 to work with the stock 2.2L crankshaft"
ECaulk is offline
Old 08-24-2015, 12:00 AM
  #131
mrbelvedere's Avatar
i know a couple of people who ran a 2.2 crower rods in a lsj with lsj pistons raised the compression 1 point
i am sure some people ran the lsj rod and piston years ago
get an accurate measurement may not be as far as you think
the book is wrong on the rods they are not a forged piece
mrbelvedere is offline
Old 08-24-2015, 01:25 AM
  #132
Also those pistons are impossible to find
Old 08-24-2015, 01:43 PM
  #133
Jegs says they got 'em. $880!
Old 08-24-2015, 09:49 PM
  #134
**** that lol. All to use a stock rod?
Eagles and wisecos are 780 shipped on ebay
Old 08-25-2015, 08:56 AM
  #135
i doubt jegs stocks ecotec parts those pistons will be a custom order
Old 08-25-2015, 09:33 AM
  #136
Not to mention if its the special gm piston they havent been made in forever
Old 08-25-2015, 09:46 AM
  #137
I was more pointing to the special part number if the guy didn't want to go with a thicker head gasket
ECaulk is offline
Old 01-12-2017, 10:33 AM
  #138
So can anyone tell me what would be need to make a 2.1 out of a 2.4 block using the crank from the 2.0 thanks have been looking but can't seem to find any info on this subject
dannysauer is offline
Old 01-12-2017, 07:16 PM
  #139
wiesco makes the 88mm pistons that fit on the LNF rods, then just use a 2.4 block and a 2.0 crank. I think zzp sells a crank sensor spacer that you might need.
04-24-2016 12:10 PM
ineedacobaltss
11-07-2015 02:25 PM
hacadacalopolis
10-28-2015 06:09 PM
patooyee
10-15-2015 05:11 PM
09-26-2015 06:44 PM
Quick Reply: Why no hybrid L61/LSJ builds?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
