ZZP Over Sized Tensioner help!
I am in the process of installing the oversized tensioner pulley. We ground down the ridged area as their instructions state. When we bolted the pulley down and tried to put the belt on - we noticed it will NOT fit. Not even a little bit We then ground down the edge of the tensioner arm that bolts onto bracket (best way i can describe it). Still not even close to fitting. I have emailed them for help - I think I may have got the wrong one? But I won't know until they see the pictures. I will post them up in a few.
that does look awful close...once we grinded down the area it said to it fit no problem but we did shave alot off...urs looks lik its about to rub on the top of the tensioner arm..it may be possible u got a wrong 1 but im not sure im no where near my car to look at mine
the pulley bolted on fine after the grinding. The problem is the gap between the tensioner arm and the pulley on the bracket. the belt will NOT fit between there. it won't fit by a lot too.
this shop thats next door just did a pulley and tensioner on another car. its GM superchargered (can't remember the model). but we went off what that dude told us. which was complete BS apparently lol
