ZZP stage 3 kits
I have GMPP stage two kit on my car now, with a ZZP intercooler. 60 lb injectors. What all do I need to step up to stage 3 ZZP and is it even worth the money? I plan on having enough money after I buy either a CTS-V or a TBSS, to do so mods to the balt. I know the trans, is going to be a weak link, but as long as I am careful, is it worth it?
Pretty sure if you already have 60lb injectors you could just slap a 2.8 pulley on it and have what a stage 3 kit could get you. You would need a tune tho. The stock trans should survive more abuse then a stage 3 kit can give it unless you rot the hell out of it.
Originally Posted by Blairwolf
(Post 7216944)
you'll be fine. just drive it right. 2.8 and 60s is pretty common with lsjs. It'll be a fun little car... make sure the tune is on point and you will have no problems.
Trifecta can tune you for the pulley. I still have a trifecta tune with my TVS since i have no one around that knows anything about hp tuners. I may not be getting all the power out of it since trifecta is conservative. But I have used them with every mod Ive made. Started out with 60s and a 2.8 down to a 2.6 with meth inj and now the TVS. I have no complaints. The car hauls ass. lol What shifter are you getting?
(Post 7216944)
You need a lot more than a stage 3 to break a trans unless you walk around with a helmet on the daily |
(Post 7216980)
GMS2 does not have 60's it has 42's
The car has a exedy single clutch kit that has 3k miles on it. The trans itself and the half shafts are all that worry me. I don't do any drop launches at a light. I dig only. As long as I hook, and don't over rev/miss a shift I should be fine correct?
Originally Posted by redcobalt08
(Post 7216990)
I built my own kit. Used pulley, and intercooler. I went 60 lb injectors to be safe, and to allow further mods.
(Post 7217000)
Oh sorry read it a little too fast. Thought you were wanting 60's.
wheel hop is what kills axles and sometimes transmissions more then anything. There are a few places that sell rotated trans mounts. They are pretty much a necessity for eliminating wheel hop lol. I got a set of stage one axles from zzp when i did my gmpp clutch kit. Haven't broke one yet, but I'm easy on the car from a dig.
GM S3, ZZP S3, etc. S3, is not going to destroy the trans
(Post 7216980)
You need a lot more than a stage 3 to break a trans unless you walk around with a helmet on the daily These transmissions are pretty tough. |
use the search button this has been covered 0765065065067456046750 times
(Post 7217008)
Originally Posted by 05RLS2
(Post 7217070)
Originally Posted by mitchk90
(Post 7217120)
^ This
Originally Posted by mrbelvedere
(Post 7217138)
| All times are GMT -4. The time now is 04:28 AM. |
