ZZP stage three 2.8 inch pulley
for installing the 2.8 inch pulley will i need to either rent or buy a pulley puller from zzp? i thought i read on some posts that for some sizes u need it and others u didnt. so i thought i would just get confirmation. also, with the zzp adjustable pulley tensioner, are there any modifications the will need to be made to the car? (i.e. grinding down rubbing points) i read that on oversized pulley tensioners that u had to do that.
come on people please give give me any info possible. i just wanna make sure i have all the proper tools for the task before i begin considering this is my first attempt at modding a car.
alrighty thanks, sorry if i sounded a bit testy but i expected responses soon. guess im too impatient. is there anything at all that i need to worry about the adjustable pulley tensioner?
I have the 2.8 and I'm running the oversized tensioner pulley which is totally fine. It was hard enough getting the stock belt back on with that setup, having the shorter belt too must be next to impossible to get back on. And the oversized pulley requires slight grinding of the bracket, but not much. I would suggest going that route.
