02 gen1 2.2 swap to an 07
I apologize if this has been asked 4.4 billion times. My 07 2.2 blew up and have been wondering what to do. A built and turbo 02 2.2 is for sale near me .I know the heads are different due to the coil packs and cams. Said engine comes with ecu and harness. Now being out of an 02 cavalier originally whay kind of problems am i going to run into harness wise. I want to research this asap so i don't miss put on the deal. As far as ik the blocks are identical as well as the f23 trans ..my question is will this 02 cavalier engine work in my 07 cobalt electrically (harness wise) if not. What all do i need to swap. My guess was the heads since they're interchangeable .
02 Caviler 2.2 with harness/ecu will not mesh with your BCM. Block should be the same but I'm assuming the reluctor wheel on the crank shaft is different which will prevent you from using 07 ECU. They do both use F23 transmissions though the casing has a different bolt pattern and are not interchangeable.
Originally Posted by jdbaugh1
(Post 7693615)
You can swap cranks. Bare blocks should be interchangeable. The Cavalier transmission will not bolt up into your Cobalt though you can swap internals. I bought I Cavalier F23 for the Quaife LSD that was in it and would have just bolted that trans in if it would work but the casings are different. Ultimately I swapped the LSD out of that transmission and into mine.
(Post 7693625)
Originally Posted by Bumsnee
(Post 7693632)
did you have to swap all of the trans and diff internals or just the diff. Im not scared to take it apart but the less i have to do the better .
As far as I know all internals are interchangeable. I just had the differential swapped and kept all other internals. I didn't do it myself because I didn't want to have to drop the trans again from screwing something up. |
(Post 7693634)
