07blackg5 Build Thread. Operation Moneypit
4 Attachment(s)
I am already balls deep in this project, but I will try to hit the major points. I'm mainly making this thread to get questions answered, but I will try to provide some sort of entertainment.
Got the car new off the lot. As it sat before I got started is: -Gt bumper and lips with ss front lip, oem fogs -tjin trunk -gen 4 projectors, tinted corners/reverse/3rd brake -bc coilovers -ottp longtube header -zzp catback -2.4 intake mani -fe5 control arms with -ottp tcabs -ottp rear sway -prothand trans inserts -NX n2o kit with wotbox for window switch -custom intake (half ebay, half weapon R) -17x9 wheels with 245/40 tires -SSBC front and rear kit I started of with goals of an 11:1 m62 build, but just recently steered to a TVS and factory 10:1 comp. Build list is as follows: -full 6 rib swap -tvs -option b/dual pass -zzp stealth h/e -zzp radiator -lsjion ported head -zzp s2 blower cams -Perf Autowerks valvesprings -stock gen 2 block (07 was gen2) -wiseco pistons -eagle rods -ATI od -zzp nbs -GM main and rod bearings -zzp phenolic spacer -ls4 tb -spec flywheel and stage 3+ clutch -ID1000's -lsj fuel rail -ottp return fuel -aem 320 e85 pump -a/c delete Hoping for close to 400 on the blower, and either a 35 or 50 shot depending on how close to 400 I am. Here is how the car sits as is in terms of cosmetics. Attachment 16879 Attachment 16880 Attachment 16881 Attachment 16882 I have a lot of pictures of the brake installs and whatnot, but thats all pretty normal stuff. Since I have an 07, the head is slightly different than the previous l61's. The cams need to be cut, and a sensor needs to be pressed on. There was a lot of ruckus about the process, but I decided to do it myself. lol https://fbcdn-sphotos-f-a.akamaihd.n...b668eadc687e86 https://fbcdn-sphotos-b-a.akamaihd.n...81689829_o.jpg Comparing the new cam journal to the oem cam sensor location: https://fbcdn-sphotos-h-a.akamaihd.n...274d47c9fb82a4 https://fbcdn-sphotos-b-a.akamaihd.n...02084eecaef51d old vs new: https://fbcdn-sphotos-a-a.akamaihd.n...7b363df3e3ddf5 The exhaust cam needed to be trimmed as well, but this is both installed: https://fbcdn-sphotos-b-a.akamaihd.n...489de6c438f754 https://scontent-ord.xx.fbcdn.net/hp...ac&oe=5554609A Right as winter was starting, I started playing with nitrous jets and afr, as well as nozzle placement. I have a full spare longblock, so I didnt care if I blew it up. Welp, blew up cyl 4 haha: https://scontent-ord.xx.fbcdn.net/hp...74&oe=558EAB6A This is where the bay sits as of this week. I actually have the radiator and fan pulled already. The random wires are a horn relay, the foglight relay, and the wotbox wires that were originally hidden under the fusebox. that will all be cleaned up: https://scontent-ord.xx.fbcdn.net/hp...ae&oe=5585E673 That should be enough for tonight. I have a few questions lined up, but will wait until tomorrow. |
Love the guts you have chopping those cams. I'd do it too if mine wasn't my only transport.
If you spent as much time reading all the bitching and moaning about it as I did, you would have done the same thing
Nice build, what are those wheels? They look sick.
Finally you made your own thread! :lol:
Originally Posted by BoostedLemonPie
(Post 7494398)
https://fbcdn-sphotos-f-a.akamaihd.n...ed4f728c5e6166
(Post 7494407)
First question.
The 2.2 ecu only has provisions for iat1 signals. What people have done in the past (from my understanding) is remove the temp signal wire from the MAF, and move it to the MAP (factory 2.2 map wont read temps, again from my understanding iat1 is read at the maf). That way the ecu can read the intake temp post intercooler. I would no longer have a pre-intercooler signal, and wouldn't be able to easily tell the difference between iat1's and 2's. I have dual interceptors, and they can be wired to accept additional 0-5v signals for extra parameters. I assume that the the maf temp signal is 0-5v like the rest of the car. Does anyone knowledgeable about the electronics of these cars chime in? I figure I can run the maf temp signal wire to the interceptor as a custom input, so that it would display my "custom" iat1 reading and iat2(registering as iat1 in the ecu) |
click
Originally Posted by 07blackg5
(Post 7494390)
I have an extra intake cam if you want to have a spare sensor to swap on, vs using the one in your car. That way you can just hot swap the cams
Once I get the car running and make sure all is well, I will let you know |
Do you plan on using the 2.5 bar map from the lsj?
havent decided which route I want to go, but most likely oem lsj
(Post 7494472)
Sell all parts, buy my car, profit.
And be slower. |
But be yellowed and mintier
Originally Posted by supernovanator
(Post 7494855)
Honestly I'm thinking about picking up an 07+ head and cams/springs/porting it. Someone bought the cheap supercharger I was going to go for. Maybe I can get bigger injectors and a ported head and run some E85 for now. There is only one E85 station nearby. I can't seem to find a used head for under $200 though.
(Post 7494872)
I will sell you the head I took off my car. I can even send it straight to lsjion haha. He's only a state away
it cost me 30 or 40 bucks to ship it to ohio from michigan. I cant see it being more than 50 bucks.
Do you have a valve spring compressor? that's the only thing that's really standing in your way. |
(Post 7494880)
Let me know if you want it.
I found a few random pictures that might be interesting. From right before dom and the mad scientist had to tear down the block and replace the piston rings i fried.. cyl 1 and 4 https://fbcdn-sphotos-d-a.akamaihd.n...97b0111a071cdb l61tb vs ls4 https://fbcdn-sphotos-a-a.akamaihd.n...6973d2fb06da96 some custom tweeter sails I made for my re xxx's https://fbcdn-sphotos-e-a.akamaihd.n...1c2903ccbd3018 https://fbcdn-sphotos-c-a.akamaihd.n...5fe9e23bd9c922 https://scontent-ord.xx.fbcdn.net/hp...fc&oe=559274D4 https://fbcdn-sphotos-f-a.akamaihd.n...d4292bd4539d7f ZZP vs my old vibrant https://fbcdn-sphotos-b-a.akamaihd.n...f44d35454bf46b old wheels after ssbc install https://scontent-ord.xx.fbcdn.net/hp...a0&oe=55514658 Had to change my coilover cartridges and the one collar was seized. had to drill out the pressure and cut it in half. no way the collar was making it all the way down the body https://fbcdn-sphotos-f-a.akamaihd.n...b63f88a15740ce |
I have a complete lsj head with 58k on it, not sure if I want to keep it yet, just depends on if this 2.8 will scratch my itch for a while. I could use the money towards other parts for sure. If I ever want to go faster ill probably kick myself for selling the head though. The last fwd car I had was an sc2, so if its 300% more thrill without going crazy with the car, I probably wont need a garage full of old parts.
spare parts are always nice to have, but sometimes you just need to liquidate.
(Post 7494891)
I have no idea if it would work or not, im no mr.b ill tell ya that much lol. im still way new to the delta platform, but im catching up quick.
You could make it work, but its a lot of extra hassle. just random things like the cam sensor differences, the pcv ports flipped around, etc. The only thing with the 07-08 l61 head is that there is no bolt hole for the lsj fuel rail hardline support, but that is easily worked around. you will probably just use the oem rail, so it wont be an issue. as far as I understand, the l61 and lsj heads flow very similar stock for stock, but the lsj has nicer casting and what not. Once they are ported, im not sure there would be much of a difference.
