07cobaltguy's Re-Re-Build Thread!!!
So, as most of you know i recently found out the limitations of the stock bottom end of the L61. It tossed a rod on my way home from work while rolling into the throttle. I am going to be updating the original post during the process. I want to use this as reference material for guys looking to do a build, down to prices, links, and information that is commonly asked for.
UPDATE: Goals, Are 400+whp and rev to 8K RPM
Here is a list of the build parts that I plan on using:
ZZP Fuel Pump Re-Wire- $29
ZZP 82# Valvesprings- $290
ZZP Neutral Balance Shafts- $270
Wiesco Forged Pistons
Eagle Forged Rods-^ $750 (packaged with pistons)
ARP Studs- $135 (From ZZP)
Cometic HG- $95 (From TTR)
Hardend Oil Pump Gears (still sourcing treating)
ARP Flywheel bolts- $25 (From ZZP)
Build total: $1594
Car already has on it:
3" TBE
2.4 Intake Manifold
78lb Injectors
57 trim turbo
Vulcan turbo Manifold (dont recommend it to anyone)
Custom Intake for the turbo
Custom Charge Pipe
Ebay Intercooler
I have started the teardown, only took a little over an hour to strip the car and basically get the engine ready to drop out. I have a few pics of the teardown:
And here is one of the damage (what i know of now):
I get to drive this in the meantime, No complaints here lol:
UPDATE 12/8/11:
Well here are some pics from pulling the motor. I havent gotten the bottom end apart yet but i did get the head off. The valves in cylinder #1 are bent from the piston free floating in the cylinder. Luckly i have another head that i can canabalize for parts.
Also i am going to make a few changes and additions to the parts list. I am talking to ZZP about their LE5 clutch kit since my Spec clutch is now in the landfill.
Anyways on to the pics:
Build total: $1594
3" TBE
2.4 Intake Manifold
78lb Injectors
57 trim turbo
Custom Charge Pipe
Ebay Intercooler
UPDATE 12/8/11:
Yeah i didnt notice till you mentioned that lol. Thats left overs from summer lol.
on the balance shafts. zzp released about a month or so ago a new stainless steel model with a stronger, longer life than the gmr's or any other balance shaft. you could also go with a balance shaft delete and run an electric water pump. faster revs and less load on the engine.
good luck on the build. when i built mine it was a ton of headaches but glad i'm done with mine.
i am at the same goal as you of 400hp but with a blower.
you can check out my build thread.
went with
94lb dual valve springs
oversize valves
stage 2 n/a cams
ported head
stock head gasket
bates sleeves
bates hardened oil pump gears
bates neutral balance shafts
weisco 10:1 pistons
eagle rods
went with
oversize valves
stage 2 n/a cams
ported head
stock head gasket
bates sleeves
weisco 10:1 pistons
eagle rods
How are those N/A cams working for you?I could imagine them having alot of overlap causing you to lose cylinder pressure from the blower but I don't know the specs on them.I bet they sound mean though,any vid clips?
here is what it sounds like with the tune vince gave us. he has the idle at like 1200rpms. trying to get it under 1k so it lopes better. its hard to do that with the 80lbs and 94lb valve springs.
Neutral Balance Shafts (Still deciding vendor)
Eagle Forged Rods
ARP Studs
Stock or Cometic HG (undecided)
3" TBE
2.4 Intake Manifold
78lb Injectors
57 trim turbo
Custom Charge Pipe
Ebay Intercooler
Eagle Forged Rods
ARP Studs
3" TBE
2.4 Intake Manifold
78lb Injectors
57 trim turbo
Custom Charge Pipe
Ebay Intercooler
Electric pump is only $299.
When i was at the track my coolant was never above 176*. and that was at the end of the pass. driving back to the pits it was already in the 160s, a few minutes of idling and i was back down to 153*.
ZZPerformance Electric Water Pump - YouTube
