Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.2L L61 Performance Tech (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/)
-   -   2.2 Turbo cooling trouble (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/2-2-turbo-cooling-trouble-166463/)
lwpmoon Apr 16, 2009 04:32 PM
So when I installed my turbo I used one of the to heater core lines. And know when I turn on the heater the engin temp rapidly rises and it starts blowing cold air. I shut it off when it gets close to 220 and it shoots up to 240 and then returns to normal. Any ideas??? Pictures below. In the first pic the tee circuled in red is the coolent going to the turbo from the heater core line. The second pic is coolant coming from the turbo into the surg tank line.
http://i716.photobucket.com/albums/w...n/DSC05928.jpg
http://i716.photobucket.com/albums/w...n/DSC05930.jpg
NWAE Cobalt Apr 16, 2009 07:15 PM
edit...pics werent labeled well...more examination needs to be done lol, label things!
could it be possible you have the two lines crossed?
ilovecars Apr 16, 2009 07:19 PM
hhmmm werid. thats why im not gonna splice off anything.
unless of course you figure it out and its a good way to do it lol.
NWAE Cobalt Apr 16, 2009 07:25 PM
thats how it has to be done lol, we did this on a buddies car about a year and a half ago lol, dont rem what we did unfort and he has moved (2.4redss)
it is the only way though, and im sure there is a logical explanation, such as swapped in and out, not enough coolant...somehting
question...front mount or direct to the tb/ intake mani????
lwpmoon Apr 16, 2009 07:54 PM
you mean coolent in and out from the turbo? Double cheaked.
Front mount.
I'm going to switch the tee to the other heater core line. My only concern is the turbo might not get sufficent cooling though so I'll have to cheak the flow. Will update with info.
ilovecars Apr 16, 2009 08:08 PM
lies im sure theres other ways.
YelloEye Apr 16, 2009 08:23 PM
The shooting from 220 to 240 after you shut it off is normal since you are effectively killing the only way for the engine and turbo to cool itself. Normally your rad fan doesn't even turn on till around 220 I believe. The blowing cool air after turning on the heater however baffles me. What is the tuning solution for your ECU?
lwpmoon Apr 16, 2009 08:33 PM
SCT (For now)
YelloEye Apr 16, 2009 08:47 PM
Originally Posted by lwpmoon (Post 3742699)
SCT (For now)
The only reason the heater would blow cold air is because there isn't any coolant getting to it to heat up the coils in the heater core.
NWAE Cobalt Apr 16, 2009 09:12 PM
Front mount.
are you tapping in before or after the coolant goes through the engine (head and block)???
lwpmoon Apr 16, 2009 09:17 PM
I beleave after the block, line going to the cabin. I'll have to cheak the direction of flow.
NWAE Cobalt Apr 16, 2009 09:20 PM
if its after the block id be willing to say its cause your taking hot coolant and putting it into the turbo and not pulling any heat with that...its just staying hot and then leaving to get cooled afterwards...i would say you would want to pull coolant before the block and put it back into the system between the block and the radiator so it gets recooled...
b_faulk75 Apr 16, 2009 10:59 PM
Sounds like you have air trapped in your cooling system.
NWAE Cobalt Apr 17, 2009 01:21 PM
that could be
