Aftermarket L61 Cobalt parts
Old 09-26-2007, 12:28 PM
  #51
cobalt07ls's Avatar
hey guys i got a L61 with weapon r secret intake borla cat backs twm shortthrow shifter and eibach 2.5'' lower sportsline spring what else can i do to make her faster???
it would be appriciated for some help haha
Old 09-26-2007, 04:02 PM
  #52
Spanky's Monkey's Avatar
spray.
Old 09-26-2007, 08:04 PM
  #53
SpeedJunkies07LS's Avatar
yeha i could but then i would have to forge the pistons rods and all that wont i ?
Old 09-26-2007, 11:03 PM
  #54
nope, not with a 75 shot.
Old 09-27-2007, 12:00 AM
  #55
no **** what would you recomend for a turbo
Old 09-27-2007, 11:39 AM
  #56
as long as you're manual i'd stick with the garret kit.
Old 09-27-2007, 12:57 PM
  #57
yeah i am garret sounded pretty good when i looked at it do they have a boost controller? and what about hahn i heard good things about them?
Old 09-28-2007, 12:40 PM
  #58
Gearblock's Avatar
if im not mistaken theyre selling the same turbo kit
Old 09-28-2007, 11:35 PM
  #59
I'm old school
Halfcent's Avatar
There is no Hahn kit for the L61. Hahn simply sells the Garrett Alpha kit.
Hahn makes a kit for the LE5 using the Garrett Tuner kit.
Old 09-28-2007, 11:52 PM
  #60
sanger11's Avatar
Halfcent, has anyone had success with SCT flash as far as a 2.2L Auto ...yes the 06 Cobalt. And how much should this cost for a tuner to do the work and to receive the tuner with the 3 custom tunes.
Old 09-29-2007, 10:24 AM
  #61
Delta2.2's Avatar
there will be no HPT software for 2.2's from 05-06. heres what HPT said about it today or yesterday i believe.
https://www.cobaltss.net/forums/show...17&postcount=6
i give up on them. SCT needs to come through for tuneing. that or a Megasquirt program or something.
Old 09-29-2007, 01:18 PM
  #62
Gearblock's Avatar
since you guys are on the topic, mind if i ask what exactly is done with tuning? is it mostly for the air/fuel ratio?
Old 09-29-2007, 08:08 PM
  #63
I'm old school
Halfcent's Avatar
"Tuning" on a modern computer controlled car is the act of modifying the software in order to control the fuel and ignition systems.
Old 09-29-2007, 11:14 PM
  #64
thats probablty true on the hahn turbo but i may have mistaken what it was that i saw when i looked at the discription hhaa but how much does a ecm usually run for the L61
Old 09-30-2007, 10:33 AM
  #65
I'm old school
Halfcent's Avatar
I don't understand the question. Are you asking what an ECM costs new from GM?
Old 09-30-2007, 11:24 PM
  #66
i mean like a performance ecm for them
Old 09-30-2007, 11:38 PM
  #67
Gearblock's Avatar
there are no tunes for the L61 except for the one that comes with the Garett Turbo Alpha Kit.
Old 09-30-2007, 11:49 PM
  #68
what you mean no tunes like computer wise or perf. wise i assume you mean comp. right haha
Old 10-01-2007, 12:02 AM
  #69
Gearblock's Avatar
well u have your stock ecm but u cant tune it and they dont have any software to tune it. if you get the garett alpha turbo kit it comes with a new one i believe but its tuned for the turbo and that turbo only, you cant further tune it yourself.
Old 10-01-2007, 08:28 PM
  #70
I'm old school
Halfcent's Avatar
^Correct
Old 10-01-2007, 10:01 PM
  #71
o ok i got ya i understand now so it comes with an ecm already programmed for the turbo or to run with the turbo got ya any other goodyies i could throw in her hhaa
Old 10-02-2007, 01:16 PM
  #72
Gearblock's Avatar
well if you're serious about the turbo i would definately consider a 2.5" or at the most 3" catback exhaust system. a better exhaust manifold would be great but i think the garett turbo alpha kit comes with one or maybe its an intake manifold...i cant remember. and unless you upgrade your engine internals i wouldnt really add on anything like nitrous cuz with the turbo you're already putting extra strain on the engine components.
and all of this is info i found off this forum, so look around and you'll be sure to find everything you need!
Old 10-02-2007, 07:17 PM
  #73
I'm old school
Halfcent's Avatar
Part of a turbo kit is a turbo exhaust manifold. It's kindda necessary. The kit retains the stock intake manifold.
Old 10-02-2007, 07:40 PM
  #74
BigTizzle903's Avatar
good stuff.... now i can easily compare mods
Old 10-02-2007, 07:49 PM
  #75
Gearblock's Avatar
hey Halfcent do all turbos run off of the exhaust?...i guess thats why u need the turbo exhaust manifold...to have the turbo between the mani and the dp... just guessing
Quick Reply: Aftermarket L61 Cobalt parts
