Catback exhaust 2.25" w/ 2.5" DP and cat - Cobalt SS Network
Go Back  Cobalt SS Network > Engine Technical Discussion > 2.2L L61 Performance Tech
Catback exhaust 2.25"  w/ 2.5" DP and cat >
Old 09-20-2018, 07:48 PM
I really want to get a header for my Cobalt. The problem is, long ago in 2013 I decided to go with a 2.25" catback.
ZZP Performance has a midlength header that looks perfect for what I want... but...
The DP included is 2.5", with no option to go 2.25".
I chose 2.25" because it is a 2.2 liter 4 cylinder engine.
The hp doesn't warrant a 2.5" exhaust, and I worried about not enough back pressure damaging the engine.
If I get this 2.5" DP and cat, is this going to make the car drive bad?
Going from a larger pipe to smaller is the opposite of optimal.
Plus, the question of back pressure and the obvious problem of mismatching.
Opinions please?
Thank you!
Mike85220 is offline
Old 09-21-2018, 08:09 PM
No it will be fine. I had the same setup
chevygirl2006 is offline
Old 09-26-2018, 09:00 AM
On a non-boosted 2.2 you most likely won't see a performance gain with an aftermarket header anyway so keep in mind this mod will be mostly for looks/sound. You may even lose some low end torque. That said, the reduction from your header downpipe to the back side of your exhaust is probably insignificant and I wouldn't be concerned about it.
Also, engines benefiting from back pressure is a myth. Engines do not need back pressure and back pressure is not good for engines. This myth is a misconception of power losses associated with larger pipes because of the reduction in exhaust gas velocity, compared to smaller pipes, which can reduce the effects of scavenging. Short summery here
jdbaugh1 is offline
XDraconis
03-05-2014 10:30 AM
FFSLOWBALT
08-06-2013 08:12 AM
fatchellparty
04-19-2012 02:02 AM
reefer_roids
08-31-2011 05:41 PM
ExHondaMan
11-05-2005 07:38 PM
Quick Reply: Catback exhaust 2.25" w/ 2.5" DP and cat
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
