Cleaned Throttle Body, idle surges now
I cleaned my TB lastnight and now idle is acting funny when I drive. When I am driving about 2000-2500 rpm's and drop it into neutural the rpm's will rise between 2500-3000 rpm instead of dropping back down. When it does go back down at stoplight it will idle at 1300-1500 rpms. I did not spray it with anything. I sprayed a rag with cleaner and wiped the inside with it.
TB connector and I pulled it off the intake manifold to clean it. Hope I did not hurt the TB when I move the plate back and forth to clean it. I might try pulling it off again and put it back on (Gasket not sealing?).
ya...did you manually move the butterfly?????
ya, just read...if you did move it then its probly screwed. seen this happen a few times...
