Cobalt Parts Interchangeability
You say that there is space for the manifold to fit into the car, but the TB won't bolt up correctly? What would it take to get the TB to bolt up?
What's the gain for this change, and is there a better/cheaper alternative to the SS part?
Does anyone know if its a Direct swap to switch Speedo/Tach gauge from a ss/sc to a cobalt ls (2006 L61, 2.2L)?
I am very interested in doing this, I love the ss gauges at night time.
The Lip From an SS S/C or the one offer through GM Goodwrench?
Bolt up it will fit but you'd have to get you ECU Reprogrammed to handle the change.
In on they just removed the Amber Lenses in place of an Amber Bulb.
It's more that the TB is electronic and will cause the car to go into Limp mode. There are no after market TB's. Crate Engine Depot has a kit to put the 2.4 manifold on to the 2.2 using the L61 TB
The other problems you will likely run into is replacing or fabricating the protective plastic under the front of the car. I hate this plastic on all GM cars with such a passion. It is the most flimsy POS I have ever seen.
Let me know how it fits and what you had to do to get it to fit. It will be mostly a bolt on but I suspect some hang ups. Probably a little bit of fabrication here and there.
I know the 32 lb injectors will fit with no leak but what about tuning? would it even be worth getting them since there is no tuning for the 2.2s yet or is it a different kind of tuning?
#37
I've tried them, they fit Leak free but the computer has a seizure, when i go Wot in second, so they wont work right now. With tuning I'm using it with a 75 shot, safer that way
#40
Does anyone know if there would be more benefit from swapping out the SS intake manifold rather than the 2.4L intake manifold? I know the 2.4L can swap with minimal effort but what about the SS? would it be even more beneficial or just about the same as a 2.4L intake?
#42
YellowLT you are pretty smart, maby too smart...
jk, question i have is could I change my drums to rotors, in a bolt-on fashion or would this require the ss/sc rear axel be swaped as well?
#44
It would require the new Hub which would mean you would need new rims in the back. You would have to change to the 5 lug. Stainless steel brake company makes a kit to do rear Disc in our car.
