Cobalt Parts Interchangeability
Old 10-25-2011, 03:57 PM
  #276
sergiochaotik's Avatar
quick question:
Will an SS aftermarket magnaflow exhaust (not the cat-back system, just the exhaust) fit my 06 cobalt LT?
Thanks
Old 10-25-2011, 05:08 PM
  #277
NWAE Cobalt's Avatar
ok...a catback IS an exhaust...so thats not exactly a clear question.
If you mean axel back or just a muffler then whoever welds it on will make it fit (aka a reducer pipe to correct sizing, redo the hangers if need be, etc).
So I suppose some clarification is in order...
but for the most part...YES, any ss/sc exhaust component will swap across
Old 10-25-2011, 06:09 PM
  #278
thanks. sorry I guess I meant without the downpipe etc.
Yea I just got it, looks like I need a 2.5in pipe, but all else looks like it will fit.
Old 12-09-2011, 01:22 PM
  #279
will the rear lip of an ss fit a regular LT bumper or do I have to change the rear fascia first, and then get the lip?
Old 05-11-2012, 03:32 PM
  #280
tyler.frederick23's Avatar
id love to know this as well, it would save SOOOOOOOOOOOOOOOOOOOOOO much money
Old 05-12-2012, 12:16 AM
  #281
there's a how to thread somewhere on this site. The guy has a black base model-but it's not direct fit.
Old 05-12-2012, 12:48 AM
  #282
YelloEye's Avatar
Look in the howto section, believe there is one about using an LS bumper.
Old 09-21-2012, 11:48 AM
  #283
Cruzzer38's Avatar
Just to clarify, you said the intake manifold wouldn't work with the 2.2 tb right? So I'd be okay as long as I got both the intake manifold and tb off a 2.4 SS to put on my LT?
Old 09-23-2012, 10:31 PM
  #284
depends what year you have. You need an 8pin tb for the 2.4 im, and the 05-06 cobalts have a 6 pin tb.
Old 09-25-2012, 01:41 PM
  #285
Cruzzer38's Avatar
I have an 07 LT. So I'm good right? Is this mod hard? Cause I'm thinking itll be pretty simple, swap em in, tune it, nd im good
Old 03-15-2013, 02:30 PM
  #286
alexhaf932's Avatar
Yes ive searched but i always get mixed answers. If i want to upgrade to a 2.4 intake manifold from a 2.2 do i need an adapter plate for the TB? If i buy the upgraded TB (LE5) will my K&N intake still fit because i read somewhere that it wont?
Old 03-15-2013, 02:43 PM
  #287
umrdyldo's Avatar
You don't have to get the upgraded throttle body. If you don't get the throttle body you would need an adapter plate. If you got intake manifold and new throttle body you wouldn't need an adapter. Only a gasket.
Your intake will most likely work as the spacing difference is minimal.
Old 03-16-2013, 04:04 PM
  #288
YelloEye's Avatar
If you go with the 2.4 throttle body you are going to need to be tuned for it to work correctly. The adapter plate can be made out of plexiglass if you're creative.
Old 03-18-2013, 10:24 PM
  #289
I'm old school
Halfcent's Avatar
You may be going about it a bit backwards...
To switch to an LE5 intake manifold while still using an L61 TB will not really help you. The air has still been metered using the L61 TB and engine program, so there won't be a difference in the air going to the engine just because the pipes are bigger.
If you get the LE5 TB with a proper tune and stick with the L61 manifold, that would work. Crate Engine Depot used to sell a the exact adapter plate you would need for such a job.
Now if you get the manifold and the TB for the LE5, then no adapter required. But as mentioned, you would need a tune to take advantage of the larger TB.
Old 03-19-2013, 12:34 AM
  #290
alexhaf932's Avatar
great informative post! why cant people give answers like this more often? anyways thanks man i really appreciate the info and advice
Old 04-21-2013, 07:22 PM
  #291
rhamilton909's Avatar
thanks man. does that also go for the 2010 base model 2.2L?
i know the suspension is between the 2005 to 2010. all the struts springs coilovers. **** like that can be changed and the bumpers can too but as far as. the injectors or interior?
Old 10-02-2013, 01:32 AM
  #292
WhiteNBlackBalt's Avatar
So I have a question. I have an 07 ls with Bad-Mab Header, ZZP downpipe w/ cat, and a CAI, would I then be able to get a used supercharger w/ intake mani and TB as well as valve springs, rods, pistions, off an 07 SS and #42 injectors from ZZP. and supercharge my LS?
Old 10-02-2013, 02:52 AM
  #293
andrewcarr1993's Avatar
No point in using the ss valve springs, they are all the same. Is just buy everything you need from mongo to SC the engine. No need to touch the internals if you're fine being at about 250 whp max.
Old 10-25-2013, 08:54 PM
  #294
KeyWho's Avatar
Hello everyone, dont if someone asked already, but will the motor or trans mount of and lsj or lnf fit my 2009 lap lt?
Old 10-25-2013, 08:57 PM
  #295
KeyWho's Avatar
Ooh and if not, could you recomend some brands, thanks....my balt had almost 70k miles when I got it, and seems previous owner couldn't care less
Old 10-25-2013, 09:11 PM
  #296
Brands for what parts exactly. Moog is a pretty good one for most parts but there are also normally better parts that cost more.
BTW the LNF rear trans mount does work on a F23 trans cobalt and for the front just get the Powell F23 rotated mount.
Old 11-10-2013, 12:18 AM
  #297
KeyWho's Avatar
hey everyone....would an SS TC throttle body fit my 2.2 LT....maybe a dumb question but got curious? Or what would be an upgrade from the stock automatic LT throttle
Old 11-10-2013, 12:50 AM
  #298
urm. i know the pins are different for the connectors. there is an adapter for it i believe though. why are you trying to upgrade your TB though? seems pretty pointless. if you want a big TB get an LS4 one but i thought i had heard somewhere there was a con to it.
Old 11-10-2013, 12:55 AM
  #299
LE5 TB would be the easiest swap, the LS4 creates a very sensitive throttle. Also if you ever go turbo'd it's not really needed but does help a bit if supercharged.
Old 11-10-2013, 02:13 AM
  #300
Thank you
Quick Reply: Cobalt Parts Interchangeability
