E85 thoughts
Anyone know a site where i can get a cheap good e85 conversion kit?
There is no E85 conversion kit. It would be a tune and injectors.
I would suggest full bolt ons first then get tune for E85 |
Rather than kit...um set? And of course.just getting goals and prices down.
80 lbs injectors are $180 i think. Since youre 2006 you have to use trifecta.
Whats the minimum cc for e85?
you could reasily run e85 on 60's with bolt ons. i knew someone running e85 on 42#'s with just intake and exhaust.
But more pounds increases performance right?
Originally Posted by Will Kravick
(Post 6373859)
I actually do recommend 60s instead of 80s because youre not boosted. I know 80s is minimum when boosted. Not entirely sure on N/A since many people dont do it. |
Incorrect.... Injector size for e85 depends on mods. I can get away with a 2.8 m62 with 60s by feeding lowend fuel more and making it leaner up top. ... I recommend 80s but they are not needed.its all in the tune.......... Also if someone had.60s and wanted to go to e and to a 2.6 he or she.can get away with it as long as they went.to a blend of e:.. I've done it plenty of times...
So with bolt ons do 60s. Hmm. So just allows more fuel. I thought e85 was thinner, is that why you need more in the engine to combust?
In order to burn at e85 stoich you'll need to burn around 20-25ish more % of fuel then gasoline..... Op if all your doing is n/a and bolt ons 42s can do it for you...... But like i said it depends on Tuner..
Originally Posted by Chevycobaltss3
(Post 6373899)
Think I could run e85 on my SC'd l61 3.0 pulley on 60's??
^: yep
Even with trifecta? Your too far away James lol
Lol I'm having a meet at my place in march. im having people coming from west coast and east coast.. your close..:P
Hmm..
thought that popped into my mind,
should i upgrade to the 60s when i do full bolt on even without e85, would the increase performance at all? |
No need unless boost or e.. you can upgrade. To stay lsj stockers and get tuned but your injectors wiill be fibe
