Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.2L L61 Performance Tech (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/)
-   -   first steps in building your engine... (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/first-steps-building-your-engine-106916/)
darkhulk12 Apr 14, 2008 10:01 PM
we all know the exterior performance mod steps,like, air intake, exhaust. springs...
What kind of things can you add or replace on the engine that would start to show an immprovment on performance???
jdub777 Apr 14, 2008 10:02 PM
s/c, turbo..
Mnatvyc1223 Apr 14, 2008 10:04 PM
higher compression pistons, springs/ retainers + cams, NITROUS... and last but not least, driver mod stage 3
rockkrawler628 Apr 14, 2008 10:11 PM
air intakes and exhaust aren't exterior performance modz
XM15 Apr 14, 2008 10:12 PM
$$$ and research before attempting a build
tru2nrtt777 Apr 15, 2008 07:23 PM
^^ True story.
ChevyRockstar Apr 17, 2008 05:06 PM
They are outside the block so they are exterior mods (does not mean outside the body)
Halfcent Apr 17, 2008 05:36 PM
If you are looking for actual performance gains, then not much. Most of what you do on the inside of the engine is designed to support the extra power from things outside of the engine. Replacing rods and pistons does nothing to your power. It just allows it to take more. Basically you should plan on what you want to do outside the engine (forced induction, nitrous) and then build the inside accordingly.
LScoupeTUNER Apr 17, 2008 05:38 PM
the great halfcent has spoken!!
