Gen 1 vs Gen 2 block?
Old 06-29-2011, 01:42 PM
Liked 0 Times in 0 Posts
Just curious what the differences are between the I-Gen and II-Gen blocks are? I keep hearing about them, and see them on ZZP. Tried to look into it with no real luck..
strykr is offline
Old 06-29-2011, 04:27 PM
The GenII has thicker mains, extra reinforcements down low and is an all around stronger block design.
Blk08coupe is offline
Old 06-29-2011, 06:25 PM
Gen II can supposedly take 600 hp on the stock block with no extra girdle bracing or whatever.
Leafydialupking is offline
Old 06-29-2011, 08:29 PM
Is the 2010 2.2 (LAP) Gen 2? or is gen1-gen2 only 2.0's
strykr is offline
Old 06-29-2011, 08:30 PM
Yeah the LAP is 2nd gen and so is the LE5.
Old 06-29-2011, 08:32 PM
So I take it the rods n pistons are still crap on these 2.2's and need to be replaced for my turbo build?
strykr is offline
Old 06-29-2011, 08:33 PM
Yup, only mainstream eco's with forged internals were the lk9, lsj, lnf, and 06-07 le5's.
Old 06-29-2011, 08:35 PM
Liked 1 Time in 1 Post
07 and up 2.2 has the gen II block I believe. someone correct me if i'm wrong
conerboner is offline
Old 06-29-2011, 08:38 PM
Brags's Avatar
You are correct 07+ l61, LE5, LAP, LNF.
Brags is offline
Old 06-29-2011, 08:42 PM
All le5's. And after 07 the have shitty powder rods like the 2.2.
Old 06-29-2011, 10:12 PM
Liked 376 Times in 333 Posts
the rods still can handle a fair amount of power with proper tuning, i'm not talking 300whp, but 240ish with a good tune is safe.
ECaulk is online now
Old 06-29-2011, 10:15 PM
Oh yeah 250 is fine on the stock rods. Hell GM proved it with nitrous. With a good tune you can see more than 250 wheel safely, not much more though.
Old 07-03-2011, 06:33 AM
By any chance, do anyone know how you can tell if a specific block is Gen 1 or gen 2 ?
I mean with a casting number, precise pics or a specific aera on the block... without having to trust a seller on the model year of the car it comes...
alanoo is offline
Old 07-03-2011, 06:58 AM
Here ya go.Everything they changed from gen1 to genII.
.Had to educate a LNF owner on another forum that did not believe me.
Originally Posted by Wikipedia
On engines produced before 2007, spark was produced via 2 coils in a cassette that bolted to the top of the valve cover which contained the boots for each spark plug on the bottom of it, eliminating the need for wires. In 2007 the L61 was upgraded with a new Gen II engine block, cylinder head improvements, new camshaft design, E37 engine control module, 58X crankshaft reluctor ring, digital crank and cam sensors, individual coil-on-plug ignition, vented starter solenoid, new MAP sensor, new intake manifold seals, new oil filter element, a 32-bit computer, and improved emissions performance.
Originally Posted by GMInsideNews.Com
2007 Ecotec 2.2L I4 ( L61 )
ECOTEC 2.2L I4 (L61) CAR AND TRUCK ENGINE
2007 Model Year Summary
• Gen II Engine Block
• Cylinder Head Improvements
• New Camshaft Design
• E37 Engine Control Module
• 58X Crankshaft Reluctor Ring
• Digital Crank and Cam Sensors
• Individual Coil-on-Plug Ignition
• Vented Starter Solenoid
• New MAP Sensor
• New Intake Manifold Seals
• New Oil Filter Element
• Improved Emissions Performance
Originally Posted by ECOTECFORUM.COM
Full Description of New and Updated Features
Gen II Engine Block
The Ecotec 2.2L starts with a refined engine block, introduced for 2006 with the Ecotec 2.4L VVT (RPO LE5). The Gen II block was developed with data acquired in racing programs and the latest math-based tools. Both the bore walls and bulkheads, or the structural elements that support the crank bearings, have been strengthened, with only a minimal weight increase (approximately 2.5 pounds). The coolant jackets have been expanded, allowing more precise bore roundness and improving the block‚€™s ability to dissipate heat. Coolant capacity increases approximately .5 liter.
The cylinder block is the engine‚€™s foundation, and crucial to its durability, output and smooth operation. For GM, the common Gen II Ecotec block increases assembly efficiency. For the customer, the result is more efficient cooling, more strength to accommodate additional power, as in the new Ecotec 2.0L direct-injection Turbo (RPO LNF) and better noise, vibration and harshness control.
The Ecotec 2.2L also benefits from cylinder head refinements introduced on the 2.4L VVT. The exhaust ports have been enlarged slightly with machining improvements to expel exhaust gas more efficiently. Both engines share a common nodular cast iron exhaust manifold, chosen for its durability and sound-deadening properties. The improvements to the cylinder head increase Ecotec 2.2L horsepower slightly in most applications (see specs).
New Camshaft Design
The exhaust cam has been re-profiled to take advantage of refinements in the cylinder head. Maximum exhaust valve lift does not change, but duration increases slightly. The cams also feature a new 4X timing reluctor, replacing timing sensors previously contained in the ignition-coil cassette (see Individual Coil-On-Plug ignition, below). The powder metal reluctor wheel is pressed onto the camshaft at the rear. The 4X reluctor improves ignition timing accuracy and maintains precise consistency over the life of the engine.
Individual Coil-On-Plug Ignition
The Ecotec 2.2.L is equipped with individual coil-on-plug ignition, or four separate coils. Each coil sits directly over a spark plug, with no wire in between. Previous Ecotec 2.2Ls had two coils in a single cassette, with each coil shared by two spark plugs. Individual coil-on-plug delivers maximum voltage and the most consistent spark density. The 2.2L‚€™s cast aluminum cam cover has been redesigned to accommodate the four coils.
An advanced controller manages the multitude of operations that occur within the Ecotec 2.2L every split second. The E37 is the S-3 Controller within GM‚€™s new family of three engine control modules (ECM) that will direct nearly all the engines in Powertrain‚€™s line-up. The E37 is the high-value variant, yet it‚€™s anything but basic. It features 32-bit processing, compared to the conventional 16-bit processing in previous Ecotec 2.2Ls. It operates at 59 MHz, with 32 megabytes of flash memory, 128 kilobytes of RAM and a high-speed CAN bus, and it synchronizes several dozen functions, from spark timing to cruise control operation to traction control calculations. The E37 works roughly 50 times faster than the first computers used on internal combustion engines in the late 1970s, which managed five or six functions.
1LowLS is offline
Old 07-05-2011, 02:18 AM
So I should definitely be safe to run the ZZP stage 2 SC setup on my stock internals as long as my tune is done well? Want to make sure because next summer I'm finally going FI with my car after 4 years of slowly building up to it. 225WHP is my goal, but if more is made off of it, I'll be happy. I say 225 because as you can see by my sig, I'm auto. I couldn't remember how much power everyone said these engines can take stock before parts need replacing.
007CobaltLS is offline
Old 07-05-2011, 02:27 AM
2007 lsj sc is gen 1 block?
rcorona8 is offline
Old 07-05-2011, 06:22 AM
yes you should be fine, just dont beat on it and take care of it and it will take care of you
07+ should be gen 2, but lsj has different internals, i would suggest looking here 2.0L LSJ Performance Tech - Cobalt SS Network for your lsj info
Old 09-28-2018, 08:53 AM
Heads
Will a gen 2 head off of a 2007 l61 work on a gen 1 block out of a 03 (I think) cavalier?
Bumsnee is offline
Old 09-28-2018, 05:33 PM
Liked 312 Times in 287 Posts
yes as long as its going into a car that uses a gen2 head.
Slowbalt2000 is offline
Old 09-28-2018, 05:40 PM
Slobodan Miloöević
07blackg5's Avatar
Liked 203 Times in 167 Posts
different crank trigger wheel
07blackg5 is offline
Old 09-30-2018, 07:58 PM
Yeah you have to use the right crank but the block doesnt matter
Old 10-10-2018, 09:28 AM
Are the crankshaft interchangeable will the Gen 1 crank fit in a Gen 2 block correctly
Bumsnee is offline
Old 10-10-2018, 11:12 AM
Slobodan Miloöević
07blackg5's Avatar
yes
04-24-2016 12:10 PM
ineedacobaltss
11-07-2015 02:25 PM
HEATON
10-16-2015 07:21 PM
Trav3480
10-01-2015 08:17 PM
anotherslowlnf
09-29-2015 03:52 PM
Quick Reply: Gen 1 vs Gen 2 block?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
