Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.2L L61 Performance Tech (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/)
-   -   Header Help (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/header-help-166693/)
boltedbalt Apr 17, 2009 07:43 PM
Header Help
okay guys here a good one for ya....i have the SS down pipe now will a header for the 2.2 fit onto the SS downpipe???? if not what header will? thanks guys!
slowswap Apr 17, 2009 07:44 PM
Minus the SS/TC, all the exhaust are the same for what bolts up.
05LSCobalt Apr 17, 2009 07:45 PM
exactly^^ i have a full SS/sc exhaust for under 150 and i can see some okay gains from it. but will be going with the zzp header and catted DP combo
boltedbalt Apr 17, 2009 07:49 PM
so will a pace setter header fit on the SS down pipe?
slowswap Apr 17, 2009 07:50 PM
Doesn't the Pace Setter require a custom downpipe because it's a mid length header?
boltedbalt Apr 17, 2009 07:54 PM
mmm thats what i have been hearing....so does the SS SC header give good gains to a 2.2? thats kinda what im leaning too...
TCASON Apr 17, 2009 09:54 PM
The SS/SC manifold will be better than the stock 2.2 mani. I have put them both together for a side - side comparison and there is a huge difference in port size and at the outlet at the connection to the DP.
They ( GM ) closed almost half the outlet on the 2.2 compared to the SC or 2.4 NA.
But a Clear Image header and DP will give you the BEST results. :twothumbs
05LSCobalt Apr 17, 2009 10:42 PM
yeah the lsj you will notice some gains
FF22 Apr 18, 2009 02:24 AM
I'm in a argument right now on another site about this since the gains are not much swapping manifolds...go aftermarket header.
boltedbalt Apr 18, 2009 01:44 PM
Does anyone have a SS SC header that i can buy for a decent price? I have the SS down pipe so i may as well just get the header to...!
bumps for a header for me!
Bump Guys!!!!!!!!!!!!
MadBrad Apr 20, 2009 01:37 PM
If you have an 07+, then you already have the 2.4 N/A / SS/SC manifold.
silver06cobalt Apr 20, 2009 01:40 PM
the pacesetter requires quite a bit of modification..
