Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.2L L61 Performance Tech (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/)
-   -   I Need Advice on Removing A Engine (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/i-need-advice-removing-engine-121514/)
Chambers Jul 10, 2008 10:07 AM
I need some advice on removing the engine, after unbolting all the obvious engine mounts and disconnecting the harnesses, what is the best route to do this, should I take the engine out from the top, or should I raise the car up around the engine and then slide the engine out?
Thanks.
joeworkstoohard Jul 10, 2008 10:08 AM
i'd just lower it out and slide the car off, but that's mainly because my garage isn't really large enough to lift it over and out.
Altiery54 Jul 10, 2008 10:09 AM
ya drop it out the bottom man
Brian MP5T Jul 10, 2008 10:12 AM
Down
Chambers Jul 10, 2008 12:08 PM
Ok, thanks, that will deffinatly quicken the removal!
D4u2s0t Jul 10, 2008 06:46 PM
Originally Posted by 2005ChevroletCobalt (Post 2579314)
get a cherry picker and rtfm (read the fucking manual)
yea... i'm pretty sure the manual doesn't say anything about taking out the engine.
tru2nrtt777 Jul 10, 2008 07:05 PM
Is there a chiltons for the balt?
XM15 Jul 10, 2008 07:06 PM
Yeah, I've got one.
tru2nrtt777 Jul 10, 2008 07:07 PM
Nice, I'll have to order one...
madmark Jul 11, 2008 12:05 AM
i went threw the top, just make sure you pull the harmonic balancer off first and it slides out pretty easy
Tazmanian_Dvl Jul 11, 2008 12:13 AM
I would support the subframe and then unbolt it and then raise the car up and pull it out if you have the ability to get the car up in the air high enough otherwise it's through the top FTW...
xtreme 2 Jul 11, 2008 03:54 PM
Due to space issues I've always removed the crossmember and dropped the motor out the bottom... but if you have the space a cherry picker is definitely easier...
Chambers Jul 12, 2008 04:37 PM
Thanks for all your replies, I have the space to pull the engine up but I think I will be taking the engine out from the bottom.
Thanks again.
