IonNinja Build
Old 03-22-2013, 10:48 PM
  #276
elecblue06's Avatar
didnt you just build the engine? please tell me you didnt use stock rod bearings ?
Old 03-22-2013, 11:58 PM
  #277
IonNinja's Avatar
Yep
Rod bearings were replaced with a new set of OEM bearings during the build.
Old 03-23-2013, 07:37 AM
  #278
usafcobalt's Avatar
Stock rods??
Old 03-23-2013, 10:12 AM
  #279
1LowLS's Avatar
Wiseco pistons,eagle h beam rods.
Old 03-23-2013, 10:57 AM
  #280
usafcobalt's Avatar
Wow that's interesting. Sure your clearances were correct? Did you break in the engine with conventional for 750 miles? No boost? Holy **** batman. Just listened to the second video. That sir is rod knock if I've ever heard it. Put some Lucas in there it will quiet it up. But I would beat on it anymore. Time for another build.
Old 03-23-2013, 01:40 PM
  #281
sounds like a damn jack hammer
Old 03-24-2013, 01:12 PM
  #282
IonNinja's Avatar
The issue isn't due to an assembly problem.
It appears to be due to an oil issue. I drained the oil and only enough to fill about 1/3 of my oil drain pan came out
Car didn't smoke so I'm not sure where the oil went lol. Honestly I'm just going to put in new rod bearings and hope i got lucky before I start looking for another block.
Old 03-24-2013, 01:34 PM
  #283
usafcobalt's Avatar
Yeah blow by. I have that problem. Catch can solved that though. What were you running for pcv?
Old 03-24-2013, 01:37 PM
  #284
1LowLS's Avatar
Mine did the same.changed the PCV valve in the intake mani and now have a catch can.all is good now.
Old 03-24-2013, 02:28 PM
  #285
armcclure's Avatar
Rings can't seat in an egg shaped hole.. Just sayin.
Old 03-24-2013, 02:39 PM
  #286
1LowLS's Avatar
Haha
Old 03-24-2013, 04:08 PM
  #287
usafcobalt's Avatar
But but but when I was a kid I made the square go in the circle. Just needed a hammer
Old 03-24-2013, 07:28 PM
  #288
1LowLS's Avatar
His cylinders aren't egg or oblong.I checked by putting the piston in with no rings to make sure there wasn't excessive wear
Old 03-24-2013, 08:52 PM
  #289
usafcobalt's Avatar
Well your no fun! All seriousness I hope some fresh bearings will straighten it out. Hopefully you didn't spin a bearing then you may indeed need a crank and or rods. Good luck man
Old 03-25-2013, 12:34 AM
  #290
armcclure's Avatar
You can't see a few thou, but your rings can. I'm not saying that was indeed the culprit, just saying if you didn't mic it, then you don't know.
Old 03-25-2013, 12:44 AM
  #291
1LowLS's Avatar
Well I can tell u the piston had no slop all the way down the cylinder and the rings have quite some movement,with a freshly honed cylinder,I'm positive they seated.but ur right I don't know for sure,biut I'm pretty dam sure.his car would of been slower than before the built engine if they weren't seated.I know my motor had no power for about 50 miles until the rings seated,then went 1000 break in.
Old 03-25-2013, 01:44 AM
  #292
elecblue06's Avatar
did you put in oil and see if it still sounds the same? when you first start running the engine you're going to **** through oil depending on the ring gap
Old 03-25-2013, 04:58 AM
  #293
IonNinja's Avatar
Same as OEM. Hose coming off valve cover to intake
Yeah I changed the oil after I swapped the head, didn't make a difference.
Old 03-25-2013, 08:33 AM
  #294
usafcobalt's Avatar
Yeah I would run a catch can in that system. What did you gap your rings to? They are supposed to be around .055. And with that gap. You will get blowby
Old 03-25-2013, 09:19 AM
  #295
armcclure's Avatar
Is rather have a little blowby than a tip-to-tip motor failure..
Old 03-25-2013, 11:49 AM
  #296
1LowLS's Avatar
I don't remember exactly what they were at but they were a tad tighter than that.
Ok
Old 03-25-2013, 12:26 PM
  #297
elecblue06's Avatar
ouch man that blows.. hopefully it's just the bearings and not the crank as well
Old 03-27-2013, 06:51 AM
  #298
IonNinja's Avatar
so I pulled the pan off tonight and the rod bearings in #3 were completely gone, top and bottom
had tons of broken pieces of crap at the bottom of my oil pan
tried new bearings and its a no go, there's still slop between the crank and rod so either the crank and/or rod is out of spec
Old 03-27-2013, 07:35 AM
  #299
bmxracerchamp12's Avatar
that sucks man. hopefully you get it back together before it gets way hot down there
Old 03-27-2013, 04:27 PM
  #300
IonNinja's Avatar
Yeah, I don't even have a engine hoist to pull the motor so I gotta figure that out.
Wish I had a bike to ride around on in the meantime lol
Quick Reply: IonNinja Build
