Can you tell a 2.2 from a 2.4 VVT from the outside?
Old 04-01-2018, 05:42 PM
Henry3959's Avatar
Can you tell a 2.2 VVT from a 2.4 VVT from the outside?
I looked at a block today with 69K on it advertised as an 08 2.4. It sure doesn't look like a 2.4. Is there any way to tell from the outside?
Old 04-01-2018, 10:33 PM
exninja's Avatar
The code on the oil filter housing should tell you
Old 04-01-2018, 11:14 PM
Henry3959's Avatar
I have the number but didn't have any service there. Now that I am home I don't see where to look it up.
197119238
Old 04-02-2018, 12:22 AM
exninja's Avatar
I looked on my old lnf filter housing and I guess it's just a serial number so nvm. They stamp a20nht on the ldk there.
Old 04-02-2018, 11:51 AM
Numbers on the timing cover tell you nothing. They all share the same cover. Oil filter housing should tell you.
Old 04-02-2018, 11:52 AM
Henry3959's Avatar
As posted above, 197119238 are suppose to be the last 9 digits of the VIN on the oil filter boss.
Old 04-02-2018, 12:03 PM
Kolt's Avatar
Using the last 8 it shows up as a 2.2 09 sedan
Old 04-02-2018, 12:05 PM
Henry3959's Avatar
Thanks Kolt... I knew you would figure it out. Any way to tell what it was pulled from? A Cobalt sedan?
Old 04-02-2018, 12:54 PM
Kolt's Avatar
Should be sedan.pdf
Old 04-02-2018, 12:57 PM
Henry3959's Avatar
That's awesome!
Old 04-02-2018, 01:02 PM
Kolt's Avatar
The last 9 you gave doesn't match though, dunno if they typod or if the 1 is for something else. with the last 8 this is the only veh it came up as. 1G1AS58H897119238
08baltls
04-13-2014 05:05 PM
Matt03785
05-04-2012 05:29 PM
2.4_SS
05-12-2009 10:57 AM
sloNlow
03-06-2006 10:12 AM
Quick Reply: Can you tell a 2.2 from a 2.4 VVT from the outside?
