issues any suggestions
Hello All new to the Colbalt scene having problems with the car heres the lay out has a 2005 ls colbalt auto with AEM instake with dry filter and mega flow full catback exhaust with 57K on the car with 18s not lowered.
The problem started a few weeks back after putting octane 91 in the car for the first time gave it some gas coming out of the gas station to beat the on coming traffic was kinda a slopping curve wheel chripped a little bit and then around 4k the car went in engine reduce power mode and was bogging bad drove a little while down the road so I could pull of to the side the engine check light came on as well as the T/C traction control light. Let the car sit for a while and it ran fine with the engine check light still on and the TC light went on to autozone to get the codes. when they ran the codes game me a P0068 and a P0105 and a traction control malfunction code which I didn't get. had the traction control code cleared wanted to see if it would pop back up later. So I took it easy on the car and been putting octane 89 in the car since. Every so often when Im at a dead stop and it to test it out when it hits 4K the car boggs aganing and engine reduce power light signal comes on as well as the engine check light and the T/C let the car sit starts up fine the T/C light go out put the engine check light stays on when I get it checked out same code P0068(Throttle position and engine load do not agree) and P0105 MaP(Man. absolute Pressure)/ Baro or Maf/VAF(Vane Air Flow) sensor condition. Did a through cleaning of the Air Filter and dried it with a blower dryer and let it sit reinstalled and later same issue. Only does it from a dead pull when rolling around 4k doesn't do it at all or when I was caught in a dirt patch was able to get it all the was to around 6k before the car pulled out any idea what could be causing the problem :poke: |
| All times are GMT -4. The time now is 10:06 AM. |
