jdbaugh1 official "build" thread
Old 07-17-2018, 02:37 PM
  #251
jdbaugh1's Avatar
Originally Posted by 07blackg5
I just have an scip sensor plugging it lol. I would tap it for a plug, but I don't want to ruin the case, even though i would probably never sell it.
Same reason I didn't. In theory I should just be able to drive the plug right on through and the bore should be good as new.
Old 09-02-2018, 04:24 PM
  #252
jdbaugh1's Avatar
Took the Cobalt on a 10-hour trip and was completely trouble free. Longest trip I have taken in a very long time. Hit 210F max temp on the way down with outside ambient temps around 97F averaging 85mph. Didn't get over 190F on the way back as it was cooler today. Ran the AC the whole time and averaged 27-28mpg. Overall was pleased with the car as she didn't let me down whatsoever.
Old 09-02-2018, 06:03 PM
  #253
63 Nova SS's Avatar
Nice!
jdbaugh1 (09-02-2018)
Old 09-02-2018, 06:34 PM
  #254
Sharkey's Avatar
sweet. its always nerve racking taking a project car on a long trip for the first time.
Old 09-03-2018, 10:38 AM
  #255
chevygirl2006's Avatar
same for me. Took mine on a 15 hour trip to pick up some seats. Got 25ishmpg and it did great.
Old 09-03-2018, 11:15 AM
  #256
jdbaugh1's Avatar
Don't you run on E85? If so you really get 25mpg on E85? If so that is very impressive. Also, when you roadtrip I assume you travel in areas were E85 is easy to find or do you bring fuel with you?
Old 09-03-2018, 12:36 PM
  #257
I took the trip on 93
Old 09-03-2018, 12:37 PM
  #258
I don’t travel long distances with e85
Old 09-04-2018, 12:56 PM
  #259
Slobodan Milošević
07blackg5's Avatar
I get like 17 on e85 lol
Old 09-04-2018, 04:51 PM
  #260
I think I get 16 max
Old 09-05-2018, 06:35 AM
  #261
63 Nova SS's Avatar
Ouch
Old 09-05-2018, 01:35 PM
  #262
Foximus's Avatar
Double digit mpg numbers? Whats that like?
Old 09-10-2018, 06:43 AM
  #263
jdbaugh1's Avatar
Happy to be able to make it out to this months "local" autocross. Missed last month. Felt a little rusty yesterday. Had trouble doing all the sections without significant errors in at least one of them along the way as you can see below. For my fastest run time (the first run in video) I screwed up the first slalom entry and it threw of my cadence for the section. For my last run I nailed a cone right off the start so I just hammered down and went through the rest of the course pretty good until the slalom right before the finish line where I came in too hot and overshot it.
Old 09-29-2018, 03:56 PM
  #264
jdbaugh1's Avatar
Same location as last time. Seems like the organizers weren't feeling real creative because course was very similar to last time. Still fun though.
Old 10-22-2018, 09:08 AM
  #265
jdbaugh1's Avatar
Old 10-22-2018, 05:09 PM
  #266
Those poor focus ST's
Old 10-22-2018, 06:07 PM
  #267
jdbaugh1's Avatar
Lol yeah I caught the one that placed 21st Raw looking over at my car when I crossed the finish line with a WTF look on his face.
Old 10-22-2018, 06:10 PM
  #268
Also, its funny that the Gstock focus is faster than the SMF cars. Driver mod?
Old 10-22-2018, 08:24 PM
  #269
jdbaugh1's Avatar
Could be but sometimes one certain mod, that doesn't really make much of a difference, will bump them into SMF. This is my first time running with these SMF Fords here so don't really know much about the drivers or cars honestly.
Old 10-24-2018, 11:10 AM
  #270
Im pretty sure any sort of tune puts you into SMF so that could be the case.
Old 11-12-2018, 12:25 PM
  #271
jdbaugh1's Avatar
I'd say I got most of the goody out of my RE-71R tires this autocross season. I flipped the tires on the wheel about half way through the season because FWD, with only ~2 degrees negative camber, wears the outside edge of much faster than the inside edge. You may also notice there are some flat spots on the tires and I think that mostly happens when my rear drum brakes lock up, under hard breaking or when one back tire is in the air from tripodding(locks then skids when remakes contact with surface), as I don't have ABS. The rear wheels become light under hard breaking and that is why I am reluctant to swap to discs in the rear because I don't need anymore rear bias. The significant disadvantage of drum breaks is they don't dissipate heat as well as discs and performance drops of when they get very hot. On a road course it would definitely be an issue but for autocross I haven't noticed any degradation on successive runs yet. I think I need more front bias. I'm considering throwing LSJ disc brake setup on the front but I'm assuming I will still need a proportioning valve. Anyone know if LSJ disc brakes will clear the base model 15" steelies?
Old 11-12-2018, 01:02 PM
  #272
Slobodan Milošević
07blackg5's Avatar
I don't believe they clear.
And I re-plumbed my entire brake system with nicopp line and incorporated an adjustable bias valve. Nicopp is extremely easy to bend and flair, and wont ever rot out. you can form it around a radius by hand, and the whole job goes surprisingly quick. having only worked with steel lines before, I was dreading doing it. The nicopp is the bees knees and easily cut the working time in half.
jdbaugh1 (11-12-2018)
Old 11-12-2018, 01:28 PM
  #273
jdbaugh1's Avatar
What bias valve did you use?
Old 11-12-2018, 01:38 PM
  #274
Slobodan Milošević
07blackg5's Avatar
wilwood. 2 in 3 out. only one line runs to the rear with a Tee in back
Old 11-12-2018, 05:43 PM
  #275
I used the summit brand bias valve that looks exatcly like the wilwood. Havent tried it out yet but my system is set up the same as mikes.
jdbaugh1 (11-13-2018)
Quick Reply: jdbaugh1 official "build" thread
